ᐅ Cleaning IKEA Metod Glass Fronts Elegantly, Even with Stubborn Dirt
Created on: 21 May 2020 08:37
Emirjan-taE
Emirjan-ta21 May 2020 08:37Hello everyone, I have glass fronts on my IKEA Metod kitchen unit, which look really great. However, cleaning can be quite challenging, especially with stubborn dirt like grease stains or small scratches on the glass. I’m particularly interested in which cleaning agents and methods can be used to treat the glass fronts gently, while still achieving a thorough clean without damaging the glass surface or the frames. Are there any proven home remedies or special products you would recommend? Also, how do you specifically handle heavily soiled glass fronts to ensure the result is elegant and streak-free? Looking forward to your tips and tricks!
Plain soapy water is not always enough for stubborn dirt. I am interested to know if anyone here has ever tried using aggressive cleaners and what risks that might involve. Glass surfaces are delicate, especially when there are coatings on the edges. Does anyone have evidence that standard glass cleaners or, for example, ammonia-based products are safe to use?
Hello Emirjan-ta, I have had good experiences with IKEA Metod glass fronts and would like to suggest a brief guideline:
- Important: Never use abrasive cleaners or harsh scrubbing pads, as the glass can get scratched.
- For regular cleaning: use warm water with mild dish soap and a soft cloth.
- For stubborn grease: a mixture of 70% water and 30% vinegar helps to dissolve grease while remaining gentle.
- Apply the vinegar mixture to the cloth, not directly onto the glass, to avoid damage to the frame or seals.
- Finally, wipe with a clean damp cloth and dry by polishing with a microfiber cloth.
A common mistake is applying too much pressure, which can increase the risk of scratches.
In short: patience and gentle cleaning agents are key.
Marlenepa21 May 2020 10:04Regarding the cleaning of IKEA Metod glass fronts, I would like to add that especially for more stubborn dirt such as burnt-on grease residues or fingerprints, a coordinated approach is advisable.
1. First, remove coarse dirt with a damp microfiber cloth and mild dish soap.
2. For heavier grease deposits, a homemade solution of water and some dishwashing vinegar (approx. 3:1) applied to a cloth can be helpful.
3. For particularly stubborn sticky residues, you can carefully use a sponge that is extra fine-pored and non-abrasive.
4. It is important to protect the frame from moisture during cleaning, as plastic parts can swell.
5. After treatment, thoroughly wipe the glass surfaces with a dry, clean microfiber cloth to avoid streaks.
This method preserves the elegance of the surface and prevents damage.
