ᐅ How can I clean Ikea Metod kitchen cabinet fronts without leaving streaks?
Created on: 6 Apr 2023 17:03
Chen_tiHello everyone,
Lately, I have been focusing on maintaining my IKEA Metod kitchen cabinet fronts and noticed that despite careful cleaning, unsightly streaks or smudges often remain. My cabinet fronts are mostly high-gloss white, so any irregularities are especially noticeable.
I am particularly interested in how to clean these surfaces so that they remain truly streak-free, without causing damage or using unsuitable cleaning products that could harm the finish.
Which cleaning products and techniques have worked well for you? Do you use special cloths or specific liquids? Is there perhaps a difference in the approach between high-gloss and matte fronts?
I look forward to your tips and experiences for gentle but effective streak-free cleaning!
Cecilera666 Apr 2023 17:09I prefer to use a microfiber cloth and lukewarm water with a little dish soap. Afterwards, I wipe it down well with a dry microfiber cloth – this way, I avoid streaks.
For streak-free cleaning of IKEA Metod kitchen fronts, I recommend avoiding harsh cleaning agents. Ideally, use a mild dishwashing detergent dissolved in warm water. A soft, lint-free microfiber cloth is best. It is important to thoroughly dry the surfaces with a dry cloth after wiping to prevent water spots and streaks.
For high-gloss fronts, gently polishing with a special glass or plastic cleaner can additionally help remove streaks.
Cecilera66 schrieb:
I prefer using a microfiber cloth with lukewarm water and a little dish soap. After that, I thoroughly wipe again with a dry microfiber cloth – that way I don’t get streaks.Thanks for sharing, that sounds reasonable. Do you use the dish soap undiluted or heavily diluted? And do you dry immediately afterwards, or let the surfaces air dry first? I ask because I think water hardness and drying time might contribute to streaks.
I prefer to take a somewhat more technical approach here, as the topic of surface care for lacquered and high-gloss fronts is quite complex.
First: The surface of Metod kitchen fronts mostly consists of MDF with a lacquered coating. This sensitivity should be taken into account, so abrasive cleaners or rough sponges should be avoided. Ammonia or solvents are also off-limits, as they can damage the lacquer.
Regarding streak formation: This typically occurs when cleaning solution evaporates unevenly or minerals remain in the water.
My approach:
- Always use calibrated, preferably soft water or good tap water without high hardness levels.
- A mild, pH-neutral dishwashing detergent in very low concentration (a few drops per half a liter (about 2 cups)) is sufficient.
- Microfiber cloths with a dense fiber structure work best (avoid cheap, lint-prone ones).
- After wet wiping, be sure to polish the surface quickly with a clean, dry microfiber cloth.
Additionally, it helps not to clean the surface in direct sunlight or in strong drafts, as these conditions encourage uneven drying.
Feel free to ask if you need more specific advice regarding your water quality or cleaning products used.
My approach:
