Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
Acof1978
17 May 2021 09:01
DaSch17 schrieb:
We are building 40Plus. The U-value is the same as for a plastic window and therefore not significant.
The windows last longer, are more ecological (since they are mostly made from natural materials), look better, and provide a more comfortable living atmosphere.
The question is whether the price difference is not significant given current building material costs. I can check if you like :-)
pagoni2020
17 May 2021 09:08
Could you add real furniture with their dimensions to this? I have the feeling that the living/dining area is already a bit tight. Is there a cupboard or something similar placed right in the middle of the hallway? The bedroom seems very narrow to me, but I can’t read the exact measurements. I would suggest drawing in the furniture and checking the clearances!
Acof1978
17 May 2021 09:16
pagoni2020 schrieb:
Could you add real furniture with exact dimensions? I feel that the living/dining area might be a bit tight. Is there a cabinet or something placed right in the hallway?
The bedroom seems quite narrow to me, but I can’t read the exact measurements. I would suggest placing furniture and checking the clearances!
We’ve already done that. All the furniture fits, and the walkways are sufficient. We didn’t want overly large rooms. The bedroom measures 3.11 m x 4.625 m (excluding plaster). With a bed length of 2 m to 2.2 m (6.6 ft to 7.2 ft), there is still about 85 cm (33 inches) of clearance for walking.
DaSch1717 May 2021 09:19
Acof1978 schrieb:
The question is whether the price difference is not significant given the current building material costs. I can gladly inquire :-)
For us, with significantly more and larger window areas, the additional cost is €4,500 including VAT (windows from the company Stöckel).
11ant17 May 2021 14:10
DaSch17 schrieb:
Have you considered wood-aluminum windows instead of foil-wrapped plastic windows? The additional cost should be affordable for a bungalow your size.
DaSch17 schrieb:
For us, the extra cost was €4,500 including VAT for significantly more and larger window areas (windows from the company Stöckel).
I have a positive impression of your window manufacturer for once; otherwise, you can look up what I think about most wood-aluminum windows here using the search terms "wood/aluminum" or "wood-aluminum" and "11ant."
18 May 2021 09:55
The dimensions and layout of the rooms are quite coherent. Personally, I’m not a fan of the walk-in closet and the fiddly built-in wardrobe options. Also, I find the living room too dark — if a few small walls were removed for more openness, this could really become “my house,” provided the open-plan area gets at least some additional uncovered window space. But my house would always have an open roof with a void space 😉
