Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
Neubau2022
29 Jul 2022 09:03
Tolentino schrieb:
There is also a technical reason to avoid it. For walk-in showers, the screed must be installed with a slope. This often means the minimum coverage over the heating pipes, usually 45mm (1.8 inches), is no longer met.
I have it in my own house; the screed had to be done on site because of this. Whether the minimum coverage was maintained, I don’t know and I don’t really care.
In our case, this is handled by the tiler who works with the general contractor. A master of his craft and a one-man show :-)
TmMike_2
29 Jul 2022 09:42
AllThumbs schrieb:
yep, my request for underfloor heating in the shower was unfortunately rejected with the same argument back then.
Which of course is nonsense.
You simply leave out one layer, or about 3-4cm (1¼-1½ inches) of expanded polystyrene insulation in this area.
And then you won’t have cold feet when you step into the shower.
AllThumbs
29 Jul 2022 09:50
TmMike_2 schrieb:
That’s obviously nonsense.
You simply leave out one layer, or about 3-4cm (1¼-1½ inches) of styrofoam insulation in that area.
Then you won’t have cold feet when you step into the shower.
There may be solutions for that. I think they used some kind of “pre-formed slope” or something similar. It was a huge plumbing company, and you either follow their system or you don’t. They were about as flexible as a crowbar...
OWLer29 Jul 2022 09:57
I also experienced problems with the division of trades and the subsequent warranty.
Underfloor heating: heating engineer
Screed: screed installer
Shower including slope and screed underneath: tiler
The general contractor completely resisted this, as the boundaries were no longer clearly traceable.
Neubau2022
29 Jul 2022 09:59
OWLer schrieb:
I also had issues with the division of trades and the subsequent warranty.
Shower including slope and screed underneath: tiler.
The general contractor completely refused because the boundaries were no longer clearly identifiable.
Didn’t they all come from the general contractor? And yes, it’s the same for us. The connection (screed) to the front door is also done by the tiler, since the front door was delivered late.
Neubau2022
30 Jul 2022 09:08
Positive news from the Bosch representative. The mechanical ventilation system will be installed in 1.5 weeks. The ground source heat pump is scheduled for the end of August. At least we have a date. Hopefully, we can move in by the end of September. We’ll see.
