ᐅ Heating circuits/thermostats for living/dining/kitchen areas with underfloor heating/heat pump
Created on: 26 Mar 2016 11:42
na4012We have the following question. Is it advisable to install separate heating circuits with individual thermostats for an open-plan living/dining/kitchen area (40 m² (430 ft²) + 14 m² (150 ft²))? The energy source is an air-to-water heat pump. As I understand it, this is a low-temperature heating system that should heat the entire space — which, from my point of view, is the whole open living/dining/kitchen area — as one unit. It’s not about having warm feet. Our builder has proposed three heating circuits with three thermostats. We are wondering whether this is really necessary or if we could save costs here. From your perspective, is there a good reason to install three (living/dining/kitchen) or perhaps two (living/dining and kitchen) heating circuits?
Thank you very much!
Um, yes, at least 4 zones are needed… and thermostats, well, with a heat pump and low-temperature underfloor heating, they actually don’t make much sense…
So it’s better not to install them and to design the underfloor heating to achieve and maintain the desired temperatures without thermostats.
DragonyxXL29 Mar 2016 15:15Mycraft schrieb:
...and thermostats, well, with heat pumps and low-temperature underfloor heating, they are basically pointless...
So better not to install them and design the underfloor heating so that the desired temperatures are reached and maintained without thermostats I had assumed that individual room control is common nowadays. We are building with a ground source heat pump. Is this generally pointless or only under certain conditions? I mean, you can’t achieve a temperature difference of 5-6°C (9-11°F) between different rooms just by adjusting the design of the underfloor heating loops, right?
Sebastian7929 Mar 2016 15:36Also, but mainly due to the adjustable flow rate on the radiator distributors.
For 40 m² (430 sq ft), we have 4 heating circuits in the living and dining area...
nordanney29 Mar 2016 15:48DragonyxXL schrieb:
I had assumed that individual room control is common nowadays. We are building with a ground source heat pump. Is that generally impractical or only under certain conditions? I don’t think you can achieve a temperature difference of 5-6°C (9-11°F) between different rooms solely by designing the underfloor heating with tighter or wider loops, right? You won’t really get temperature differences like that in modern houses anymore. We once turned the heating off completely in the bedroom just for fun. With the door closed, the difference to the other rooms on the same floor was only just over one degree.
