Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
- Exterior lighting
Neubau202228 Apr 2022 22:07Hausbau 55 schrieb:
I have not seen a heating load calculation. There were only two excerpts from the construction specifications.Possibly better here, right in the middle.
Summary:
- Average pipe spacing of 10 cm (4 inches) (a smaller maximum would be better, of course)
- Heating load calculation
- Hydraulic balancing.
And here again is the cross-section of the floor slab. The insulation is located beneath the slab.
Hausbau 5528 Apr 2022 23:05Neubau2022 schrieb:
Maybe better here. Right in the center.
Summary:
- 10 cm (4 inches) average spacing for installation (Maximum spacing would be better, of course)
And here again the structure of the slab foundation. The insulation is installed beneath the slab.
I haven’t read your entire thread unfortunately. But based on these details regarding the floor construction, I withdraw my earlier criticism about the insulation of the hot water pipes. Your heating load calculation for this building should be around 30 to 40 pages. Designing the system for a 35°C (95°F) flow temperature is really just standard practice. You could get a lot of advice in another forum focused on heating systems. For very well insulated houses, a target flow temperature of 30°C (86°F) should be aimed for. With a bungalow (like yours), this is not quite as "simple" as with a compact townhouse. Our bungalow is much smaller at 90 m² (970 ft²), we have a flow temperature of 31°C (88°F) with natural ventilation, and 13 heating circuits. My air-to-water heat pump has a maximum heating load of only 3.5 kW.
Neubau2022 schrieb:
I have actually been here for a few years already 😎But that doesn’t come close to 60 years of experience :pN
Neubau202229 Apr 2022 05:28ypg schrieb:
But that doesn’t come close to 60 years of experience :p I was referring to the two external construction supervisors 😎
Hausbau 55 schrieb:
there are 13 heating circuits for that.They have the same here.
Basically, I would request the heating load calculation "for the records." A target temperature of 35°C (95°F) is really not very ambitious.
It will work, and you can’t always optimize everything during construction. That leads to aging.
Neubau202229 Apr 2022 07:27OWLer schrieb:
They have the same issue here.
Basically, I would request the heating load calculation “for the documents.” A target of 35°C (95°F) is really not ideal.
It will work, and you can’t always optimize everything during construction. That just makes you older. The scope of work is the standard template he hasn’t updated for years. I have already spoken with the managing director. Of course, it won’t be based on the scope of work. But I’m happy to bring it up again 😎
