ᐅ LED Recessed Ceiling Lights in Prefabricated Home Construction
Created on: 26 Mar 2015 15:05
kernm23
kernm23
26 Mar 2015 15:05
We are currently in the process of planning our prefabricated house.
Does anyone have experience with whether these prefab house manufacturers (Schwörerhaus, Weberhaus, Keitel-Haus) also offer ceilings with LED spotlights? What additional cost should I expect for this?
Thank you.
Doc.Schnaggls
27 Mar 2015 14:42
yes, at least for Weberhaus, I can definitely confirm that LED ceiling downlights can be installed.
The additional cost for the LED downlights naturally depends on the type of lights you choose and the quantity.
We installed a total of 27 LED recessed downlights from Nobile. If I remember correctly, the price was around EUR 120 - EUR 130 per ceiling downlight (including wiring and installation).
However, our LED wall downlights for the stair lighting were quite expensive – the seven lights cost about EUR 200 each.
Regards,
Dirk
28 Mar 2015 00:25
Doc.Schnaggls schrieb:
We installed a total of 27 recessed LED spots from Nobile. If I remember correctly, the unit price was around EUR 120 to EUR 130 (including wiring and installation).
Our LED spots in the wall for the stair lighting were really expensive, though – the seven spots cost about EUR 200 each.
I think that’s really expensive! We have about half that number... whether LED or halogen shouldn’t make much difference when it comes to wiring and installation. I assume at least the fixture (without the bulb) costs about the same?
Did you have to order these during the house planning stage since it’s a prefabricated house where recessed lights might already be accounted for at the factory, or were you able to order them directly through the electrician during the interior finishing phase, who installed them afterwards?
asks Yvonne
Mycraft28 Mar 2015 09:02
Just order halogen bulbs and switch to LED later... Savings of over 50% are guaranteed...
28 Mar 2015 09:48
No, I’m asking about the built-in components @Mycraft ... The light bulbs are not what cause the costs.
Manu1976
28 Mar 2015 10:01
In our prefab house, we installed the LED spotlights in the ceiling afterwards. Since the ceilings in prefab houses are usually made of drywall, retrofitting them is not a problem. The only thing to watch out for is the installation height of the ceiling spotlights.
