Hello everyone, I have a question that might sound simple but is quite specific for me: Is it possible to convert or modify IKEA Malm beds, which are originally designed as classic bed frames, into something that can actually be used as a sofa?
I don’t mean just temporarily placing a mattress on it, but creating a kind of permanent sofa alternative with a backrest, possibly an adjustable seat area, and reasonably comfortable for sitting.
Has anyone had experience with such a conversion or perhaps technical tips on how to make it stable and functional? I’m interested in the construction, handling of the back parts, and whether it’s even feasible without the bed becoming unstable or losing its aesthetic appeal.
Thank you for your assessments!
The MALM beds are designed as flat sleeping surfaces by default and do not include an integrated backrest or a folding mechanism that would allow easy conversion into a sofa.
In theory, the frame could be structurally modified to add a backrest, but this would require installing a sturdy support structure and possibly altering the bed frame itself. The challenge is that MALM frames are designed for lying down, so their load-bearing capacity and structural stability differ from what is required for sitting. A flexible adjustment of the seating surface is not intended without significant modifications.
In my opinion, there is no simple and reliable solution. Those with the necessary technical knowledge can make adjustments, but this may compromise both stability and aesthetics.
I understand your question well 🙂 MALM is a nice and simple piece of furniture. While you can be creative and try to turn it into a sofa, as a general rule you should know that MALM beds do not have built-in padding or backrests.
If you want to make it comfortable, you definitely need a backrest that you either buy separately or build yourself, for example using wooden slats or a padded structure. It might also be possible to attach a kind of removable backrest to the bed frame.
It is important that the attachment is very stable, so you don’t feel like everything will fall apart when sitting. You should also consider the height; the sofa should be ergonomically designed to make sitting on it enjoyable.
This requires patience and perhaps some basic DIY skills.
That’s brilliant, such DIY ideas! 🙂
I think if you want to convert a MALM bed, it’s a great project! You could even make a backrest from soft fabric and foam, attaching it to the frame. That way, it would feel more like a real sofa.
Have you ever thought about adding small armrests? They would definitely increase comfort. Maybe you could recycle old cushions to make it cozier.
If anyone has done this before, please share your tips! I want to give it a try too 😉
RETRAVIS schrieb:
The MALM beds are designed as flat sleeping surfaces by defaultI agree with that. The load requirements for sitting are different from lying down, which should not be underestimated.
If you want to convert the bed into a sofa, I recommend building a stable backrest structure from wood or metal that is securely screwed in.
In addition, you need suitable cushions with firm foam density; otherwise, you will quickly sink in, which reduces comfort.
As a compromise, I considered using the bed as a guest sofa with large back cushions without major modifications, but this is no substitute for a real sofa.
