ᐅ IKEA Godmorgon Cabinet – How to Combine and Secure It?
Created on: 9 Jul 2020 21:16
F
Franky73
we purchased the wall cabinet Godmorgon from IKEA as well as a countertop (which is 1.36m (4 ft 6 in) long), into which our built-in washbasin will be installed later. Our wall is made of hollow brick Unipor and has a thickness of 17.5cm (7 inches) in the installation area in the rough construction stage, plus plaster.
Now, like many others, I am wondering:
  • Which screws and wall plugs (anchors) do I need to securely mount the Godmorgon cabinet to the wall?
  • Once the countertop with the built-in washbasin is installed on top, should it be additionally supported with brackets (heavy-duty brackets)? If so, which kind?
We just want to make sure that if the children lean on or even sit on the countertop, everything will hold securely.
I really appreciate any tips or experiences you can share.
Yaso2.017 Oct 2021 14:16
kbt09 schrieb:
Then just choose a slab and have the basin integrated into it 😉.
For me, it has to fit right away; I’m not one to tinker with it.
But it’s not a big deal now. We had the bathroom furniture planned by our kitchen supplier (provider Nobilia), and if we like it when we see and feel it in person, then we’ll go with that 🙂
Stefan001
2 Nov 2021 22:01
We customized our Godmorgon a bit by adding a custom countertop and a small extension. We also decided not to mount it on the wall. It now stands on four of the Godmorgon legs. This is for the guest bathroom.
In the bathroom, the same setup with a double sink will be installed in the next few days.
Kitchen base cabinet being installed, wooden countertop on the base unit
Sink on wooden countertop, white cabinet underneath, gray towel, soap, green figurine
Sink on wooden table, white drawers with black handles, towel on the right.
White drain pipe visible under the sink, wooden slats and a metal angle bracket next to it.
E
exto1791
15 Nov 2021 13:22
Stefan001 schrieb:
We also customized our Godmorgon a bit with a custom countertop and a small extension. We decided against wall-mounting it. It now stands on four of the Godmorgon legs. This is for the guest bathroom.
In the main bathroom, the same setup with a double sink will be installed in the next few days.
[ATTACH alt="IMG_20211102_194252.jpg"]66704[/ATTACH][ATTACH alt="IMG_20211102_212250.jpg"]66705[/ATTACH][ATTACH alt="IMG_20211102_212308.jpg"]66706[/ATTACH][ATTACH alt="IMG_20211102_212332.jpg"]66707[/ATTACH]
Do you already have the double sink setup for your bathroom?
We are planning exactly the same 🙂
Is the vanity also from Ikea for your double sink?
Stefan001
15 Nov 2021 13:33
Yes, it is actually finished. The base cabinet is also from IKEA, and the two small shelves were custom built to fit.
Double sink on wooden table with white cabinets, black handles, and towels beside.
Double vanity with two basins, wooden countertop, white cabinets, gray tiles, towel underneath.
E
exto1791
15 Nov 2021 13:59
Stefan001 schrieb:
Yes, it is actually finished. The base cabinet is also from IKEA, and the two small shelves were built separately.
Looks stylish!
We have two separate sinks and would like to buy two 80cm (31.5 inch) base cabinets each (GODMORGON TOLKEN) – with one continuous 160cm (63 inch) countertop – all from the Godmorgon series.
I find the prices simply unbeatable... I think it will serve its purpose well!
Stefan001
15 Nov 2021 14:18
We have the 120cm (47 inches) model, and the washbasin is 125cm (49 inches).
It’s best to carefully consider how the unit will actually be installed and how everything fits together. We had a serious mess with the trap and the reinforcing bar on the back, which unfortunately is located exactly where the water connections and the drain are.
Do you want to mount the furniture on the wall and completely avoid using legs?
