ᐅ Are there specific Ikea Pax solutions designed for small bathrooms?
Created on: 12 Jun 2020 08:13
timothy51
timothy51
12 Jun 2020 08:13
Hello everyone, I am currently planning the renovation of my small bathroom and came across the Ikea Pax systems, which are known for their flexibility. My specific question is: Are there any Ikea Pax solutions that are particularly well-suited and space-saving for small bathrooms? I am especially interested in compact, modular options that optimize storage without overwhelming the space. Has anyone had experience with Pax in small bathrooms or knows of specific combinations that have worked well there? I look forward to any tips and recommendations!
gekira
12 Jun 2020 09:47
The Ikea Pax series is primarily designed for bedrooms, but modifications for bathroom areas are possible if certain factors are considered. For small bathrooms, it is advisable to use Pax mainly as a storage solution for towels, cleaning supplies, or laundry, since the cabinets are quite deep (up to 58 cm (23 inches)). However, there is no specific "bathroom Pax line" from Ikea. Depending on the room size, narrow models with a width of 50 cm (20 inches) can be used and fitted with smooth, handle-free doors to avoid visual clutter. For damp rooms, it is essential to ensure the furniture is not exposed to water permanently and is preferably protected with a water-resistant coating. Another option is to equip Pax with suitable interior pull-outs and baskets to make optimal use of the storage space.
barda6
12 Jun 2020 10:22
Pax is generally suitable if the bathroom is not too small. For very tight spaces, it is better to choose narrow cabinets. Make sure to consider moisture protection. Internal organizers are useful.
danial60
12 Jun 2020 11:05
I would like to elaborate a bit more on this topic. The Ikea Pax systems are indeed very versatile, but there are specific conditions to consider for bathrooms that should not be overlooked. First of all: although Pax is not specifically designed for bathrooms, it offers opportunities through modular customization, especially in small bathrooms. Narrower frames (50cm (20 inches)) are recommended, or even modifications you make yourself, such as shortening the frame parts to adjust the depth for small niches. It is also important to treat the material properly against moisture. Ikea does not offer waterproof surfaces for Pax, so I would suggest applying a water-repellent lacquer or a film coating afterwards. For the interior, baskets made of plastic or special moisture-resistant materials are suitable. Additionally, cabinet lighting and stylish organizers can be used to improve visibility and organization. Another consideration: if you plan space for doors with mirrors, they can visually enlarge the room while also serving as storage. If windows or ventilation options in the bathroom are limited, the door thickness and hinges should also be taken into account to ensure maximum use of space. Ikea itself refrains from including direct sensor systems, like those in boiler-optimized furniture, so good planning and customization are crucial.
pinDavid
12 Jun 2020 11:46
If you have limited space, choose narrow Pax wardrobes with sliding doors. This saves space by eliminating the need for door clearance. Also, make sure to use moisture-resistant interior fittings.
Tause
13 Jun 2020 07:34
I think it is important not to uncritically accept that Pax is always the best solution for small bathrooms. Pax was originally designed for bedrooms, which means its depth and height are often not ideal for saving space in tight bathrooms. Even though Ikea offers many customization options, the system’s fixed depth remains problematic.
gekira schrieb:
For small bathrooms, it is more advisable to use Pax as storage for towels, cleaning supplies, or laundry, since the cabinets are quite deep (up to 58 cm (23 inches)).
This point clearly highlights the limitation for me: in bathrooms under 4 sqm (43 sq ft), 58 cm (23 inches) depth can take up almost half the room. In addition, there is often a lack of proper moisture sealing, which raises concerns about durability.
What alternative ideas do you have for optimizing space without the cultural dominance of Pax? For example, solutions with narrow shelving systems or base cabinets that are genuinely water-resistant?
