ᐅ Are there storage solutions specifically designed for Ikea Metod kitchens?
Created on: 7 Sep 2016 08:17
carmelomu
carmelomu
7 Sep 2016 08:17
I’m currently considering how to best equip my new Ikea Metod kitchen with suitable storage solutions. Are there storage options specifically designed for the Metod system that fit perfectly into the cabinets while taking the existing dimensions into account? It’s important to me that I don’t have to do a lot of modifications afterwards, but rather rely on proven solutions that are functional and durable.
Perhaps someone knows practical inserts, drawer organizers, or adjustable shelves that were developed specifically for Metod? Any tips for optimizing the use of interior space, for example in the base cabinets or wall cabinets, would also be very helpful. Thanks in advance for your feedback!
tutan
7 Sep 2016 08:46
Hello!
You’ve chosen a very interesting topic. The Metod kitchens are really quite popular, and of course, storage needs to fit perfectly. Ikea actually offers a whole range of interior fittings specifically designed for Metod.
Classic examples are the VARIERA drawer inserts, which fit perfectly into the Metod drawers. They make organizing cutlery, pots, or food much easier. There is also the Maximera drawer system, also perfectly matched to Metod, featuring particularly quiet runners – with that, tidying up can actually be fun!
Of course, you can also look at third-party systems specializing in Ikea kitchens, but Ikea's own solutions usually fit excellently and are reasonably priced.
Josan
7 Sep 2016 10:03
Hello!
I would like to add that one of the main advantages of the Ikea Metod systems is the compatibility within the individual modules.
In addition to the VARIERA and MAXIMERA inserts mentioned by tutan, there are also special internal drawers, baskets, and dividers that can be chosen depending on the cabinet size and your needs. The internal drawers for base cabinets are particularly useful – you can neatly stack pots and pans and pull them out easily.
It is important to measure carefully before purchasing, as Metod offers different heights and depths to ensure the storage solutions fit perfectly.
The drawer fronts are partly interchangeable, allowing the entire system to look consistent – so you can combine different inserts if you want.
pauPierce
7 Sep 2016 11:22
this thread aims to raise an interesting question, to which I would like to contribute more technical information.
IKEA Metod is a modular kitchen system with a clearly defined grid standard: the cabinets come in widths (e.g., 40, 60, 80 cm (16, 24, 31½ inches)) and heights (e.g., 80 cm (31½ inches) for base cabinets) with an installation depth of 60 cm (24 inches). This simplifies the selection of organizational solutions because compatible interior fittings are precisely matched to these dimensions.
Metod drawers typically have a usable width of about 56 cm (22 inches) since the frame material reduces each side by 2 cm (¾ inch). Therefore, VARIERA boxes, which are often offered in two widths (33 cm (13 inches) and 50 cm (20 inches)), are perfectly designed to subdivide drawer areas efficiently.
Another option is the use of multi-level pull-outs (for example, 2- or 3-tiered) that can be installed in the base cabinets. These solutions offer significantly more storage space while maintaining the same cabinet footprint.
One recommendation: when planning, also consider the internal cabinet height, as drain pipes in sink cabinets often limit storage space – here, flexible interior solutions with removable inserts can be very helpful.
Are your cabinets 60 cm (24 inches) deep (standard), or do you have, for example, the tall cabinet solution? This information is important to find suitable solutions.
carmelomu
7 Sep 2016 12:05
pauPierce schrieb:
A recommendation: When planning, also consider the interior height of the cabinets, as drain pipes in sink cabinets often limit storage space – variable internal solutions with removable inserts can be helpful here.
That’s a very good tip, thank you. My kitchen includes a sink cabinet and several base cabinets with the standard depth of 60cm (24 inches). The cabinets are rather tall (about 80cm (31.5 inches)), so I wanted flexible options specifically for the sink area, since I have to account for the siphon there.
Josan schrieb:
The so-called pull-out internal drawers in base cabinets are especially useful – you can stack pots and pans neatly and pull them out quickly.
These pull-out internal drawers sound interesting. Do you or anyone else have experience with whether they fit when the interior height is limited? Can they be retrofitted, or is it better to use a full system from Ikea?
I would prefer to avoid complex structural changes and instead use more pragmatic solutions.
Josan
7 Sep 2016 13:44
carmelomu schrieb:
These interior pull-outs sound interesting. Do you or anyone else have experience whether they fit in spaces with limited internal height? Can they be retrofitted independently, or is a complete system from Ikea necessary?
The interior pull-outs are designed to be compatible with the internal height specified by Ikea, taking pipes into account. However, they vary depending on cabinet depth and height, so precise measurements are important beforehand.
Many of these solutions are available as retrofit options and include mounting hardware. Installation is generally straightforward and does not require specialized skills, as Ikea designs the systems for end consumers.
If the space is limited, for example by a trap, the interior pull-outs can be adjusted to a smaller height or individual shelves can be removed. It is worth consulting Ikea’s documentation or seeking advice in the store to find the right set.
