ᐅ How can I build IKEA Metod cabinets ergonomically for small kitchens?
Created on: 27 Nov 2023 08:39
O
onbalen
O
onbalen
27 Nov 2023 08:39
Hello everyone, I am planning to furnish my small kitchen with IKEA Metod cabinets but am unsure how to achieve the best ergonomic setup. I am particularly interested in tips on how to organize work surfaces efficiently in limited space, and whether there are specific cabinet combinations or built-in options that help protect the back and maintain freedom of movement. Also, any advice on maximizing storage so that frequently used items are always within easy reach would be great. I want to avoid constantly bending down or stretching too far. Does anyone have experience with this or can offer concrete recommendations on how to arrange the Metod system as ergonomically as possible in small rooms?
Gloriagl10
27 Nov 2023 09:12
I would recommend using tall cabinets for pantry storage and base cabinets with pull-out drawers. This way, you can avoid bending down too often. Aim for a worktop height between 90 and 95 cm (35 to 37 inches), which is usually ergonomically suitable.
TEOZAR
27 Nov 2023 10:48
Regarding the ergonomic setup of IKEA Metod cabinets in small kitchens, I can offer some insights. First, it is important to adjust the countertop to a comfortable height for you; in small kitchens, I have often found 91–93 cm (36–37 inches) to be a good height. Frequently used items and tools should be stored in easily accessible base cabinets with pull-outs, as this helps prevent back pain caused by bending down or reaching too low. Tall cabinets provide ample storage space but should not obstruct the flow of movement in your kitchen. I recommend installing as many drawers as possible, as they offer better organization and overview. For very small kitchens, you can also consider small corner solutions with rotating shelves or specialized corner pull-outs from IKEA or third-party suppliers to make optimal use of the available space. It is also essential that the countertop area leaves enough room for movement so you don’t feel cramped while cooking.
Tobias
27 Nov 2023 11:27
Prefer pull-out cabinets instead of simple shelves. Many people do not use the base cabinets efficiently because they are too deep. Work with heights of approximately 90 cm (35 inches) and use the upper row of cabinets for items that are used less frequently.
daalessio
27 Nov 2023 13:56
A key aspect of ergonomic planning for small kitchens with IKEA Metod is the arrangement of zones: the work surface, cooking area, and sink should be positioned close to each other while still allowing enough freedom of movement. With Metod, the modular cabinet height is an advantage, as it enables the countertop to be adjusted to a personalized ergonomic height. For even greater comfort, I recommend using soft-close drawers and smooth-running drawer slides, especially in tight spaces, to reduce the effort required. For small kitchens, shallower cabinets can also be helpful – IKEA offers 37cm (15 inches) depth, which often provides sufficient storage without overwhelming the space. Lastly, a tip: ensure there is adequate lighting under the wall cabinets to enable ergonomically comfortable work.
V
Vinlen
27 Nov 2023 14:22
Ergonomics in small kitchens often require compromises. One option is to choose a combination of base cabinets about 80 cm deep (31.5 inches) from the Metod series and slightly shallower tall cabinets to maintain freedom of movement. However, a proper working height is crucial, even if it means customizing the standard fronts. I also recommend placing the most important utensils in upper drawers to avoid frequent bending. Using adjustable dividers in the drawers allows you to store small kitchen tools in an organized and easily accessible way.
