ᐅ How can I best install IKEA Metod kitchen units with plenty of storage space?
Created on: 7 Nov 2022 08:23
Antoine43
Antoine43
7 Nov 2022 08:23
I am currently planning the installation of an IKEA Metod kitchen unit and want to incorporate as much storage space as possible without making the kitchen look cluttered or overwhelming. My main question is: How can I best design IKEA Metod kitchen units to maximize storage?
I am particularly interested in specific advice on choosing cabinet boxes and types, clever planning of interior organization (e.g., drawers, pull-outs, shelves), as well as tips for optimal space utilization. It would also be helpful to know which combinations have proven to be especially functional and durable in practice.
The room is about 3.5 meters (11.5 feet) long and 2.4 meters (7.9 feet) high, and the unit should be as space-saving yet versatile as possible. The more practical tips, the better. Thanks in advance!
TEBILO
7 Nov 2022 09:17
Hello Antoine43,
your question is very well phrased, and I will go step by step to help you get the most out of IKEA Metod kitchen units with plenty of storage space.
1. Cabinet size and types: IKEA Metod generally offers base cabinets 60 cm (24 inches) wide, available in different heights (60, 80, 92 cm / 24, 31.5, 36 inches) and depths (37 or 60 cm / 15 or 24 inches for base cabinets). For maximum storage, I recommend the 80 or 92 cm (31.5 or 36 inches) high base cabinets, as the drawers and pull-outs provide more volume. Tall cabinets (40 or 60 cm / 16 or 24 inches wide) are suitable for pantry items and appliances.
2. Interior organization: Drawer inserts are essential for organizing cutlery, pots, and pantry goods. Combine deep pull-outs at the bottom (e.g., for pans) with shallow drawers on top for cutlery and smaller utensils. One tip: full-extension drawers with soft-close are more expensive but much more durable and convenient.
3. Space utilization: Since you have 3.5 meters (11.5 feet) available, I would suggest using two large base cabinets as main units (offering very good storage) and adding one tall cabinet next to them. This is perfect for storing items that are not needed daily. If the run ends with a corner cabinet, you can gain an additional 10–20% more storage space.
4. Back panels and stability: Don’t forget to install the back panels carefully, especially with tall cabinets, to ensure stability; otherwise, load-bearing capacity will suffer.
5. Ergonomics: Make sure the drawers and pull-outs are easily accessible and nothing blocks them. If you have a cooktop or sink installed, plan the surrounding cabinets accordingly.
I am also curious whether you intend to use only Metod cabinets or if you plan to add supplements, e.g., additional interior pull-outs or systems from other manufacturers?
I hope this gives you a helpful first overview.
gesar32
7 Nov 2022 10:45
To complement Tebilo’s explanations, I explicitly recommend the following approach:
- Be sure to use the IKEA planning software to get an accurate visualization of the Metod kitchen unit and to try out different configurations.
- Prioritize storage based on function: dry goods, cookware, appliances, Tupperware, etc. Choose specific cabinet types accordingly (e.g., drawers with dividers for cutlery, tall drawers for pots).
- Keep load limits in mind: Metod base cabinets support about 30–50 kg (66–110 lbs) per drawer. For tall storage with heavy items like pots, stable drawers rated for 80 kg (176 lbs) are advisable.
- To maximize storage space, consider corner cabinets with rotating shelves (carousel systems) or Le Mans pull-out units. These greatly improve accessibility.
- Vertical use: select tall wall cabinets that reach up to the ceiling for items you rarely use.
In conclusion: document your priorities and measurements carefully during planning; this is the only way to avoid problems during installation.
Antoine43
7 Nov 2022 11:02
TEBILO schrieb:
I am also interested in whether you plan to use only Metod cabinets or if you are considering additions, for example with extra pull-outs or systems from other manufacturers?
Thank you for the detailed response. Basically, I plan to primarily use Metod components to maintain consistency. Additions with pull-outs from other manufacturers are generally possible, but I want to keep the effort as low as possible and prefer to use original IKEA solutions, such as VARIERA boxes and inserts.
Do you think this will limit the storage space? I want to stay as flexible as possible but avoid a full remodel by third parties or complicated retrofits.
TEBILO
7 Nov 2022 11:26
Antoine43 schrieb:
Do you think this limits the storage space?
No, not necessarily. IKEA offers a variety of well-designed internal organizers with the VARIERA and METOD series, which are tailored to precise measurements. The VARIERA range includes cutlery trays, plate holders, storage containers, and many practical accessories that fit perfectly in the drawers. Additionally, the METOD pull-outs have standardized dimensions, allowing you to expand them modularly and adapt them to your needs.
If you want to be even more efficient, pay attention to the internal height of the drawers: there are shallow, medium-height, and deep drawers. Deep pull-outs are very important for pots and larger items.
The biggest advantage of the original IKEA solution is clearly the straightforward compatibility—parts fit together exactly, and assembly is manageable even for DIYers.
I’m also curious: Do you have a specific idea of how you want to integrate your cooktop, sink, and refrigerator into the kitchen run? This significantly affects the cabinet configuration.
LUISABEL
7 Nov 2022 13:55
A brief addition to the previous posts:
- When dealing with Metod kitchen units, pay attention not only to the number of drawers but also to their internal organization (e.g., compartments for smaller kitchen utensils).
- The combination of drawers with full extension slides for better accessibility is extremely important. This ensures easy access to items stored at the back.
- Another tip: use the space above tall cabinets for open or closed storage, for example with wall cabinets or cover panels, especially if the ceiling is higher, to create additional storage space.
- Apply the concept of zones: preparation, cooking, cleaning – to divide the kitchen area into functional sections.
This approach proves effective in practice and helps maintain clarity despite having ample storage space.
