ᐅ Clever and Practical Storage Solutions for Small Kitchens with Ikea Metod Units
Created on: 8 May 2018 07:52
Francesco
Francesco
8 May 2018 07:52
Hello everyone, I am planning to equip my small kitchen with the Ikea Metod system and am particularly interested in how to use the storage space as cleverly and practically as possible. I am especially curious about which combinations of base cabinets, drawers, and internal organizers work best in small kitchens to make the most of the space while maintaining good accessibility. Are there proven strategies to maximize storage in limited areas without it becoming cluttered or inconvenient? I would also appreciate tips on which additional inserts or organizers work especially well with Metod. Thank you for your opinions and experiences!
ixlu1
8 May 2018 09:33
Hey Francesco, great topic! 😊 I’ve installed Metod in my small kitchen as well, and I can tell you: drawers are essential! You should definitely choose full-extension slides so you can pull the contents out completely – it saves time and frustration.
- Narrow cabinets (40 cm or 60 cm wide) are perfect for making the most of corner spaces.
- Internal pull-outs and storage dividers are very helpful to keep everything organized.
And my absolute recommendation: STARFJALL insert boxes for small items. This makes everything much tidier and easier to overview! Good luck, you’ll see, the system is really great!
poted
8 May 2018 13:07
Hello Francesco, I would like to provide a more detailed response to your request. In small kitchens, it is essential to use the available storage space efficiently in multiple dimensions. The Ikea Metod system does offer flexible, customizable modules.
Some important points:
- Base cabinets with 2-3 deep drawers are usually more efficient than single doors with fixed shelves because they allow better access.
- Corner solutions like the METOD corner base cabinet with a carousel (Magic Corner) can make tight corners usable, although the maximum load capacity should be considered.
- The choice of internal fittings is crucial: insert trays, dividers, cutlery trays, and shelves enable organized use.
- When planning, you should pay close attention to the internal height of the cabinets, especially if you want to store wide and tall pots.
I would also be interested to know the exact layout of your kitchen (single row, L-shape, U-shape?), as this influences the choice of suitable Metod components.
Francesco
8 May 2018 15:14
poted schrieb:
I’m also interested in the exact layout of your kitchen (single row, L-shape, U-shape?), as this affects the choice of suitable Metod components.
Thanks for the detailed information! My kitchen is a single row about 2.5 meters (8 feet) long and 60 cm (24 inches) deep, basically a single-wall kitchen. There are no corners, but there is limited space on the side walls. I’m thinking of planning with several narrow cabinets and drawers to stay flexible.
My challenge is to store frying pans, pots, groceries, and smaller kitchen utensils neatly. I want to avoid having items constantly lying on the countertops, but I cannot add extra walls or small cabinets.
tielto
8 May 2018 18:21
Based on the description of a 2.5-meter (8.2-foot) row without a corner solution and limited space, I recommend the following layout using Ikea Metod:
- Use base cabinets that are 40 or 60 cm (16 or 24 inches) wide with two to three full-extension drawers.
- Utilize internal drawers for smaller kitchen tools like cutlery or cutting boards, which can be easily adjusted in width.
- Plan for sufficient space between the sink and stove for a better work surface.
- Use shallow shelves in the upper cabinets for spices or cans.
Keep in mind that a clear zoning by function (storage, cooking, washing) is helpful to streamline workflows.
janeo
8 May 2018 21:42
I find the suggestion about insert boxes interesting, but I wonder if, in the long run, it might actually create extra work when tidying up.
Also, I often see people in small kitchens relying on too many storage boxes, which can end up making storage more complicated rather than simpler. It seems important to me to find a balance between order and quick access.
What do you think? Is managing many small boxes really practical, or are there more pragmatic solutions?
