ᐅ How can I install IKEA Metod cabinets efficiently in limited spaces?
Created on: 23 Jan 2018 08:43
waldo4Hello everyone,
I plan to install several Ikea Metod kitchen cabinets in my small kitchen, but unfortunately, I don’t have much space available. My room is just under 2.4 m (7 ft 10 in) wide, and I still want to maximize storage without overcrowding the area. Therefore, my question is: How can I best arrange Ikea Metod cabinets in a limited space to make the most of the available room, maintain functionality as much as possible, and ensure the cabinets are installed securely and neatly? Do you have any tips on planning, selecting cabinet sizes, and installation, especially for small or narrow kitchen layouts? I would also appreciate advice on useful combinations when you have very limited space and perhaps rather narrow corners. Thanks in advance for your support!
pauPierce23 Jan 2018 09:18Hello waldo4,
It’s great that you already have the room dimensions, as that is the most important starting point. When installing Ikea Metod cabinets in small kitchens, you should pay close attention to two main points:
- Choosing the right cabinet width: Metod offers base frames in widths of 20, 40, 60, up to 80 cm (8, 16, 24, up to 31 inches). In tight spaces, it’s better to use narrower units more frequently so they can be grouped flexibly. This way, you can also make better use of small gaps.
- Selecting a practical height: The standard is 80 cm (31 inches) tall base frames plus countertop, but taller cabinets (e.g., 88 or 100 cm [35 or 39 inches]) offer ergonomic benefits, especially if you often work standing up.
- Using corner solutions: Corners are challenging in small areas. Corner pull-outs like the Phoenix or Le Mans systems are very effective because they make storage space genuinely usable. If your corner is too narrow, you can also replace corner cabinets with hinged doors by U-shaped base cabinets.
- Utilizing planning software: Ikea provides a Metod kitchen planner software that allows you to precisely test how the cabinets will fit beforehand. Be sure to enter your room dimensions correctly, including wall thicknesses and any radiators.
- Assembly: In small rooms, it’s advisable to fasten the cabinets directly to the wall rather than leaving them freestanding, as stability otherwise decreases quickly. Additionally, you should cut the baseboards and countertops precisely to maximize the use of space.
One more question for you: How high are your ceilings, and are you planning to include wall cabinets as well? That would significantly increase storage capacity.
Mentioning the use of corner cabinets is important. Especially in tight spaces, it makes sense to opt for interior pull-outs that maximize the effective use of space.
Additionally, I recommend choosing pull-out cabinets with full extension, as this significantly improves ease of use.
It is also worth considering sliding doors or folding doors instead of standard hinged doors to avoid unnecessarily restricting movement space. This is often less well known but frequently underestimated in small kitchens.
pinJustin23 Jan 2018 10:05For limited spaces:
- Use many base cabinets 40cm (16 inches) or 20cm (8 inches) wide.
- Extend wall cabinets up to the ceiling.
- Utilize corner solutions with a carousel.
- Cut the countertop to fit precisely.
This saves space and increases storage capacity.
pauPierce schrieb:
One more question for you: What is the height of your ceilings, and are you planning to install wall cabinets? That would significantly increase your storage space.The ceiling height is just under 2.5 m (8 feet), so it’s high enough for larger wall cabinets. However, the wall where the installation will be isn’t continuous; there are radiator recesses near the top, so I can’t build cabinets all the way up to the ceiling. Still, I want to make the most of the space, including wall cabinets where possible. Do you have any recommendations on how to accommodate the recesses, and are there specific Metod wall cabinets designed to visually fill these gaps well?
pauPierce23 Jan 2018 12:14waldo4 schrieb:
Are there any recommendations on how to accommodate the niches and whether there are specific Metod wall cabinets designed to visually fill these gaps well?Yes, basically you can choose from various heights for Ikea wall cabinets: 40 cm (16 inches), 60 cm (24 inches), 80 cm (31 inches), and even 92 cm (36 inches) are common heights.
You can visually adapt the niche walls around radiators with so-called panels or trims, so the wall cabinets form a continuous line. Open shelves or high-gloss panels as cladding can also visually conceal the gap.
Alternatively, there are special corner solutions or two-part cabinets that you can combine at two heights to leave space for the radiator. This is more complex to install but worthwhile both visually and functionally.
Are you working with classic Metod fronts, or do you also plan a combination with other elements, such as open shelving?
