ᐅ How can I install IKEA Metod cabinets efficiently in limited spaces?
Created on: 23 Jan 2018 08:43
waldo4
I plan to install several Ikea Metod kitchen cabinets in my small kitchen, but unfortunately, I don’t have much space available. My room is just under 2.4 m (7 ft 10 in) wide, and I still want to maximize storage without overcrowding the area. Therefore, my question is: How can I best arrange Ikea Metod cabinets in a limited space to make the most of the available room, maintain functionality as much as possible, and ensure the cabinets are installed securely and neatly? Do you have any tips on planning, selecting cabinet sizes, and installation, especially for small or narrow kitchen layouts? I would also appreciate advice on useful combinations when you have very limited space and perhaps rather narrow corners. Thanks in advance for your support!
lukin
23 Jan 2018 14:39
Hello waldo4,
You have described the situation with limited space very well. I would like to add that in small kitchens, making use of the full room height is often key.
- For the wall cabinets, you can adjust the coverings using adhesive or frame construction to compensate for slight height differences.
- Additionally, baseboards and trim strips need to be cut precisely to prevent gaps next to the units.
- If you place appliances in the kitchen corner, make sure the door opening angles do not exceed the limited space available.
- Lastly, use internal organizational aids like pull-outs and drawers with compartments to make the best use of the cabinet interiors.
Using the Ikea kitchen planner is highly recommended. You can enter the exact dimensions of your radiator recesses to visually check how everything will fit.
funau
24 Jan 2018 07:51
Additionally, I would like to point out the following:
- Make sure that the countertop in small kitchens is designed to be as thin as possible and without impractical overhangs in order to use every centimeter (inch) effectively.
- In small rooms, choosing the right cabinet fronts is crucial: smooth, light-colored surfaces create a sense of spaciousness and prevent the kitchen from feeling cramped.
- Regarding installation: the most important thing is to anchor the cabinets to the wall at least at two points per unit. This increases stability, especially for tall wall cabinets.
- Narrow, tall cabinets with drawers offer better organization and easier access compared to deep base cabinets.
Overall, I recommend consistent planning based on storage priority: What do you need regularly? What do you use less often? This way, you avoid unnecessary clutter.
sonplo
24 Jan 2018 11:27
Additionally, a tip: For small kitchens, it’s worth considering vertical solutions—such as tall cabinets or shelves that make use of the available height.
Also, a recommendation: Include any planned electrical appliances in your design from the start. This allows you to optimize the cabinets and avoid potential space conflicts early on.
One more important note regarding stability: Make sure to securely attach cabinets to solid wall areas—drywall is often unsuitable, so special anchors may be necessary.
tanhau
24 Jan 2018 13:09
Important:
- Use narrow and tall cabinets.
- Use corner solutions with a carousel.
- Install wall cabinets up to the ceiling.
- Fit countertops precisely.
These are the key points for small kitchens with Metod cabinets.
pauPierce
25 Jan 2018 08:17
funau schrieb:
- Make sure that the countertop in small kitchens is designed to be as thin as possible and without impractical overhangs to make the most of every centimeter.
I want to emphasize this again. Especially in small kitchens, a standard countertop that is about 3.8 cm (1.5 inches) thick and has an overhang of 4–5 cm (1.5–2 inches) is used too often. This wastes valuable space.
waldo4 schrieb:
My room is just under 2.4 m (7 feet 10 inches) wide, and I still want to maximize storage without overcrowding the space.
This clearly calls for a very precise, coordinated approach: work with a kitchen professional or at least use a kitchen planner tool like the one from Ikea and plan the exact distances to the walls and the widths of the individual modules. This way you can optimize the space without relying on standard dimensions that often leave gaps in small rooms.
My recommendation: also use additional components like slim pull-out shelves between the main cabinets, which are often overlooked but fit perfectly in narrow gaps. They offer many advantages and add valuable storage.
If you like, I can gladly explain the setup process step by step – the most important thing is the preparation, including exact measuring, because that is where mistakes often happen.
