ᐅ Is it also possible to assemble IKEA Metod kitchens yourself for U-shaped layouts?
Created on: 28 Oct 2020 08:17
pasauHello everyone,
I am currently planning my new kitchen and am researching the IKEA Metod system in detail. My kitchen will have a U-shape, and I’m wondering if assembling the Metod system myself is straightforward with this layout.
I understand that IKEA primarily facilitates straight kitchen units, but how does the system handle a U-shaped configuration? Are the angles and corner solutions in the Metod system flexible enough to allow for the modules to be self-assembled and adjusted?
Perhaps some of you have experience building a U-shaped kitchen and can share whether the self-assembly is more complex compared to other layouts, and if there are any specific challenges or traps to watch out for during the installation.
I would appreciate any tips, experiences, or advice regarding suitable connectors or necessary adjustments!
A U-shaped kitchen with IKEA Metod is generally quite feasible.
The system is modular and offers various corner solutions, such as corner base cabinets and special corner cabinets with folding doors. The main challenge lies in the precise measurements and accurate wall dimensions. Since a U-shape has two corners, particular attention should be paid to the joining angles and overall stability.
Several users report that the upper section of U-shaped kitchens can be tricky because the wall cabinets need to be precisely aligned to work well together.
My advice: Plan the U-shape carefully using the IKEA planning tools and check all the necessary corner components separately before making a purchase.
Very interesting question! 😊 I built a U-shaped Metod kitchen myself and can say it definitely works! Of course, it requires effort and patience, but it is very rewarding to assemble the kitchen on your own.
The key is to choose the right corner base cabinet, preferably one with rotating shelves. This makes the most efficient use of the space. And don’t worry, with some DIY skills, tools, and YouTube tutorials, it’s definitely manageable!
Don’t be discouraged—it will look fantastic!
I agree with Donar34: Building a U-shaped kitchen with Metod is possible but requires precise measurements and some DIY skills.
Especially the corner solutions are not just standard modules; they also require careful installation, and with a U-shape there are two corner points in the room that need to be carefully coordinated.
Additionally, you should pay attention to wall distances and any irregularities, as these—if not compensated for—can complicate the cutting of countertops and on-site adjustment of the cabinets.
My recommendation: Plan thoroughly, preferably using the official IKEA planning tools, and check all corner pieces separately to avoid unpleasant surprises.
I understand that the idea of building a U-shaped kitchen yourself can feel a bit intimidating at first. I felt the same way when I planned my kitchen.
If you’re unsure, it can help to spread the assembly over several days and always have someone there to assist you. Especially with the corners, it’s easy to feel overwhelmed on your own.
And don’t worry – even if you run into difficulties, most problems can be solved with patience. It’s a great feeling to have built the kitchen yourself!
