ᐅ How do I install Ikea Metod wall cabinets for an open-plan kitchen?
Created on: 24 Aug 2021 19:38
Lago51
Lago51
24 Aug 2021 19:38
Hello everyone, I am planning to install Ikea Metod wall cabinets in my open kitchen and have some questions. Specifically, I’m interested in how to mount them securely, ensure they hang straight, and make sure they visually fit well with the open floor plan. What tools and fastening materials would be recommended, and are there any practical tips to keep in mind when hanging wall cabinets? I would also like to know if there are any special recommendations for open kitchens, for example regarding sightlines or ventilation. I look forward to your tips and experiences!
LEOIX
24 Aug 2021 20:17
Interesting question, because with open kitchens people often underestimate how much the wall cabinets influence the overall look. Many just hang them on the wall and think that’s enough. But it’s not! If you don’t adjust the cabinets with millimeter precision, they will look sloppy. Definitely use a spirit level and pay attention to the mounting brackets on the wall. And honestly: why always settle for standard? Consider adding extra shelves or lighting to create contrast. An open space practically demands a statement, not something plain. This is more than simple installation – it’s design!
FLOMARCOS
25 Aug 2021 06:44
Check the wall for load-bearing capacity beforehand. Secure cabinets with appropriate anchors. Use brackets to ensure they hang securely. Use a spirit level for alignment. Keep a safe distance from the cooktop.
Liduta
25 Aug 2021 08:55
I am happy to provide a brief guide for installing Ikea Metod wall cabinets in open kitchens.
1. Preparation: Check if the wall can support the weight of the cabinets including their contents.
2. Gather tools: Drill, cordless screwdriver, spirit level, screwdriver, wall plugs and screws suitable for the type of wall.
3. Attach mounting rails: Metod wall cabinets are usually hung on special mounting rails. These must be installed perfectly level.
4. Prepare cabinet carcasses: Attach doors (or do this later), and install interior fittings if applicable.
5. Hang and adjust cabinets: After hanging, carefully check alignment and adjust height and horizontal positioning as needed.
Common mistakes: rails not installed level, using wall plugs that are too weak, hanging cabinets without proper wall support.
In an open kitchen, it is also worth positioning the cabinets so that the fronts look attractive, as they are visible from multiple angles.
Lago51
25 Aug 2021 10:14
LEOIX schrieb:
If you don’t adjust the cabinets to the exact millimeter, they look sloppy.
This is actually a key point for me. Are there any technical aids or tricks to achieve this precise adjustment easily?
FLOMARCOS schrieb:
Keep a distance from the cooktop.
I wonder how much clearance is actually recommended because of heat and steam. Can you provide specific values?
One more detail: I have cavity brick walls – does anyone have experience with the best types of wall plugs and screws to use here? Thanks!
Linavin
25 Aug 2021 13:08
To adjust a Metod wall cabinet in open kitchens, we first need to determine how technically necessary a 'millimeter-precise' positioning actually is.
Lago51 schrieb:
Are there any technical tools or tricks to achieve this exact adjustment easily?
A spirit level is absolutely essential, possibly even a laser level if precision is required. However, what seems more important to me is the question of the wall structure.
Regarding the distance from the cooktop: Official IKEA Metod instructions recommend a minimum distance of 50 cm (20 inches) to protect against heat and grease damage. This distance should not be reduced.
Specifically about hollow bricks: The load-bearing capacity is crucial here. Nylon anchors are often too weak; metal expansion anchors or chemical anchors are better options if the budget allows.
