Created on: 2 Oct 2017 23:25
R.Hotzenplotz
Hello everyone!
R.Hotzenplotz26 Jun 2018 19:3211ant schrieb:
But where is your problemI don’t have a problem with it, the general contractor does!! The entire wall at the top of the plan is already allocated for solar technology, heating systems, hot water storage, etc. The main utility connection box is in the way, and he says it can’t stay there. I really don’t care where that thing is installed. But they are insisting that I have it changed, otherwise they can’t continue working. They also told me that the utility connections are clearly marked on the upper wall in the plan, not on the right side.
R.Hotzenplotz26 Jun 2018 19:52matte1987 schrieb:
Lol. Then your general contractor should handle it. It’s his problem, not yours. His construction site, not yours.He frames it so that the utility provider and the billing for services are not within his scope of responsibility (since this is not part of the construction contract). He says I’m the contact person for the utility provider. In principle, he’s right about that. At most, I can argue that I also was not informed where exactly the house connection box is supposed to be installed.
However, I also have doubts about whether the planning documents clearly state that the house connections should be installed on the uppermost wall according to the plan. No one has commented on this yet. Should the house connection box have been specifically mentioned separately?
matte1987 schrieb:
Lol. Then your general contractor (GC) should take care of it. That’s his problem, not yours. His construction site, not yours. I would be cautious with that. Of course, the GC has to solve the problem, but in the end, it’s your house and a lot of money. Basically, I’d always recommend solving problems together. If you just leave him alone, he might end up doing something you don’t like at all. He might deduct a few dollars from the invoice at most, but you’ll have to live with the mess forever.
R.Hotzenplotz schrieb:
But they are insisting that I have it changed, otherwise they cannot continue working. They also tell me that the utility connections are clearly marked at the top of the wall on the plan, not on the right side. Who is demanding the change? - if I understand correctly, it’s the heating contractor:
The heating contractor says he needs the entire wall and cannot install anything there. However, he also would not have been able to install the previously planned system there, because the energy connection is located on that wall. Whether it’s inside a box or not, it is basically marked there—covering it with a box is to be expected; and the box as a housing does not mean that this connection must be accessible. You cannot simply place the heating equipment in front of it as shown on the drawing.
The heating contractor will have to look for another wall and change the overall system layout, or the general contractor must arrange and pay for relocating the utility connection box to the wall with the other connections.
Even if you sealed the envelope with the plan to the utility provider: the plan was drawn up by the general contractor, and as a layperson, you cannot identify the mistake. So it is the general contractor who misinformed the utility provider.
The utility provider is acting entirely correctly by following the plan and not interpreting wall markings. The electrician is also acting correctly when he only works on the box from the output side and leaves the input side (and thus the box location) as the utility provider specified. The general contractor must review the plans before sending them out!
