Sebastian793 Sep 2015 13:36You mean the thickness? Your network provider knows that – do you want to embed PVC pipes in concrete yourself? I would first talk to the utility company to see if they accept that – normally, they handle everything, including the connection to the building.
They didn’t do anything there – so they can’t complain either 😉
flo30977 schrieb:
Hello forum,
My electrician is still on vacation, so I’m hoping for a quick answer here.
What type of electrical cable needs to be run from the utility provider’s cable, in our case Süwag, into the distribution board in the basement?
Florian Your electrician needs to calculate this based on your power requirements.
Doc.Schnaggls4 Sep 2015 14:07alexm86 schrieb:
Your electrician has to calculate that based on your requirements.Hello,
I would tend to doubt that.
Laying and selecting the cable is the responsibility of the utility company, which also installs the meters and makes the connection.
Are you getting a multi-utility connection installed in your house, or are you using separate inlets?
Regards,
Dirk
Sebastian794 Sep 2015 14:23Nonsense – for a single-family house, you already have a standard connection. The application is submitted by the homeowner themselves – the electrician is not involved in this process.
