ᐅ Floor plan design shortly before submitting the building permit application
Created on: 2 Oct 2017 23:25
R.Hotzenplotz
Hello everyone!
As some users have requested before, I’m now starting a new thread with the current planning of our detached house, which is about to be finalized.
These are the preliminary drawings for the building permit / planning permission application, and I have one last chance to review them and point out any issues.
It still seems to me that there is less than 1.20m (4 feet) of space between the two wardrobes in the dressing room. Or am I seeing this wrong? Apparently, the rooms on the left and right were overlooked and not adjusted accordingly.
Two Velux ceiling spotlights are still planned to illuminate the upper floor hallway.
In the basement, on the right side in the upper room, a window similar to the one on the left basement side is an option.
We still haven’t decided on the T30 fire-rated door to the garage, even though it is shown in the plans. Most likely, for safety reasons and the limited use of the kitchen at the other end of the house, we will eventually forgo it.
User 11ant pointed out that the right window in child’s room 2 is suboptimally positioned. However, this could still be changed after submitting the building permit / planning permission application. Our architect thinks moving the window to the left would negatively affect the house’s exterior appearance. We’ll have to see about that.
R.Hotzenplotz24 Jun 2018 16:10I didn’t understand the purpose of that pipe either. There is the guest toilet below it and the roof above. It’s a mystery to me.
Yes, I also think that such a casing needs to be made in the dimensions of the bed. I believe that can be worked out.
R.Hotzenplotz schrieb:
Yes, I also think that such cladding needs to be made to the dimensions of the frame. I believe this can be resolved. Before the screed installers arrive, otherwise it will be a hassle again. And with clear height specifications, "before or after Christ"
R.Hotzenplotz24 Jun 2018 16:36Good thing you mentioned that. They told me that the drywall installer would come only after the screed is laid, to discuss and finalize those matters with us.
How can I argue to them that I want to have that done beforehand?
I think there should be an insulation strip around it, just like with masonry walls. I wouldn’t want the screed to rest directly on it. Don’t forget sound insulation, otherwise it will become a perfect resonance chamber.
I didn’t understand either what the pipe is supposed to be for. Below it is the guest toilet. Above is the roof. It’s a mystery to me.Soil stack venting above the roof (for drainage pipes). Otherwise, the stack would act like a “pipette” – if it’s closed at the top, nothing drains out at the bottom...
