Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
TmMike_2
24 Aug 2022 19:52
Neubau2022 schrieb:
If you look here, you can see a stair pattern.
Yes, but the spacing is irregular – not uniform. You have to like that.
Neubau2022
24 Aug 2022 19:54
OWLer schrieb:
And that must not happen with the random tile pattern. But of course, it always depends on what you ordered.
Nothing was ordered. He has been a master tiler for many years, so I assumed he would choose the right option. I will discuss it tomorrow.
Tolentino24 Aug 2022 20:10
I had a tiler explain to me that this is the way to do it with these large-format tiles because tiles never lay perfectly flat but tend to have a slight curve or hump. With large-format tiles, this difference becomes much more noticeable towards the edges. If the tiles are laid with too much offset next to each other (in extreme cases a 50% offset), the highest point of the hump on one tile will meet the lowest point on the next one, which can even create a tripping hazard.
That’s why the offset is kept smaller. It was also indicated on my tiles: a maximum of 20% offset.
Here it looks more like 10%, maybe @Neubau2022’s tiler is just being very careful or the tiles are particularly warped.
The reason the offset is not always exactly the same has to do with the wood grain pattern—it makes the layout look more natural.
Neubau2022
24 Aug 2022 20:44
Tolentino schrieb:
I once had a tiler explain to me that this is how it’s done with these large-format tiles because tiles never end up perfectly flat but tend to have a slight hump. With large-format tiles, this difference becomes much more noticeable towards the edges. When tiles placed next to each other have too much offset (in extreme cases 50% offset), the highest point of the hump on one tile will align with the lowest point on the adjacent tile, which can even create a tripping hazard.
In this case, it looks closer to 10%, maybe @Neubau2022’s tiler was simply very careful or the tiles are quite warped.
The reason not to always use exactly the same offset has to do with the wood pattern — it makes the result appear more “natural.”
Thanks for the explanation. I’ll ask for clarification again tomorrow :-)
24 Aug 2022 21:37
Neubau2022 schrieb:
If you look here, you can see a stair-like pattern.
you can see it… it definitely shouldn’t look like stairs with such a long format. @Tolentino explained it very well.
Neubau2022 schrieb:
He has been a master tile setter for many years,
I think “many” is a bit too much to handle the wood-look tiles in 120cm (47 inches). It’s okay with 30x60cm (12x24 inches).
Since you haven’t agreed on anything, or you actually like it, I wouldn’t criticize him now.
Neubau2022
24 Aug 2022 21:50
You can tell… it definitely shouldn’t look like a staircase with such a long format. @Tolentino explained it perfectly.
I think there’s too much “zigzag” effect to work well with the wood look at 120cm (47 inches). At 30x60 (12x24 inches) it’s fine.
But since you haven’t decided otherwise, and you like it, I wouldn’t criticize it now.
In our opinion, there’s nothing to criticize either. By the way, he’s in his 40s, so far from retirement age :-)
I’ll just ask how something like this is installed, so I don’t stay clueless :-)
