Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
driver55
19 Aug 2022 11:17
This is a door hinge; the fitting is used to open the door. And yes, these concealed hinges are generally only just becoming popular… in single-family houses…
Neubau2022
19 Aug 2022 11:30
And yes, these concealed hinges are generally just starting to become common… in single-family houses…
OK. Thanks for the information. I thought this was already standard :-)
Neubau2022
22 Aug 2022 11:04
And we continue. The plastering will be finished today. The base coat color is still missing. The main bathroom should be completed as well. The posts for the fence are being installed.
White round column under canopy; construction area with cables, yellow protective ring on top, van next to it.
Tile installation: large gray tiles around a wall corner; bucket with tile adhesive in front.
Modern house with white facade, large glass sliding door, construction site with ladders and pallets.
White building facade with gray base, construction path next to the house, ladder on the right.
Construction site: white van with open door, stacked concrete blocks and wooden planks.
Neubau2022
22 Aug 2022 17:54
The exterior plaster is complete. The bathrooms have been fully tiled. In reality, the bathrooms appear brighter than the photos suggest.
White single-family house with dark window frames, columned porch, construction pallets in front of door and car
Gray tiled wall with mosaic section at the bottom; small cardboard package attached to the wall.
Unfinished bathroom wall with dark tiles, mosaic strip, and light tiles; pipes visible.
Dark gray wall tiles with silver mosaic strip; open shower pipe connections visible.
Gray bathroom with bathtub by the window; large-format tiles on wall and floor
Neubau2022
23 Aug 2022 17:44
Things are moving quickly now. Concrete is being poured at the front for the fence. However, the team accidentally cut through the telephone line... The telecom company will come on Thursday to fix it. At the back, the terrace is being constructed. Inside, the tile floor is being installed.
Baustelle am Wohnhaus: Erdarbeiten, Paletten, schwarze Drainagerohre, unbefestigter Boden.
Heller Holzlaminat-Fußboden in einem Flur, Türöffnung im Hintergrund, Treppenzugang rechts.
Innenraum mit teilweise verlegtem Holzdielenboden auf rohem Beton, helle Wände, rechte Säule.
Metallzaun mit Betonfundament entlang Baustelle am Straßenrand, Erdarbeiten.
Steffi33
23 Aug 2022 17:54
Phew… the installation pattern is unusual… but knowing you, it’s probably exactly the way it should be 😉
