Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
- Exterior lighting
Then choose a rainy day. This kind of work is possible with sun, but it gets really dark in the rain.
How about a fixed terrace roof with adjustable louver panels? You can slide them to one side when you want more light inside (in winter or on rainy days) and extend them when the sun is shining.
Climbee schrieb:
Then choose a rainy day. This kind of thing works with sunshine, but it gets really dark in the rain.
How about a fixed patio roof with adjustable louvers? You can slide it to the side when you want more light inside (in winter or on rainy days) and extend it when the sun is out. Since the structural calculations are already approved, we can no longer remove the fixed roof. I am looking into other options.
Acof1978 schrieb:
Since the structural engineering approval is already completed, we can no longer remove the fixed roof.I don’t see a problem with that. Louvers can still be installed there.https://www.instagram.com/11antgmxde/
I don’t see a problem there. Louvers still work in that case.The roof will have to be recalculated then, or am I mistaken? Doesn’t it play a role in the structural calculations?
Acof1978 schrieb:
The roof will need to be recalculated then, or am I mistaken?At the corner of your terrace, there is a 36x36 cm (14x14 inch) beam visible. Isa) the terrace covered by your house’s hipped roof, or
b) is there a separate extension with a flat roof planned?
In case a), this fully affects the structural engineering of the house,
in case b), you can choose various roof types (glass, louvers, awnings, etc.)
You can also leave the rafters above the outdoor seating area uncovered like a pergola, as I don’t consider the roof covering crucial for structural bracing. You can then install slats underneath.
