Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
Neubau2022
28 Jul 2022 23:27
The drywall installation has been completed. Next week, the tiler will come, and the fireplace will be finished. In the garden, the flat-plate solar collectors are still being installed diligently. The drainage system, as well as the electrical and water connections, are also being set up in the garden.
Construction site in the forest: excavator digging earth mound, shovel in front, trees and greenhouse behind.
Shell niche with green drywall panels on walls and ceiling; uneven floor.
Construction status: green drywall panels, installations for sink at bottom right.
Reggert
29 Jul 2022 06:50
This gap next to the toilet is probably intended as a shelf, right?
There are heating coils from the underfloor heating in the shower, correct? In our case, the entire area was left out—I’m just wondering why.
Neubau2022
29 Jul 2022 07:08
Reggert schrieb:
Is that gap by the toilet meant to be a shelf?
In the shower, are those heating coils for the underfloor heating? In our case, the whole area was left out, and I’m wondering why.
Yes, that will be an illuminated shelf. Two more will be added: one directly above the bathtub and another inside the shower partition. But the tiler will handle that. As for why they were left out in your case, I don’t know :-)
29 Jul 2022 08:15
Reggert schrieb:
In our case, the entire area was left out—I’m wondering why.
The reason the specialist installs heating cables in the walk-in shower is so that in smaller bathrooms, the heating system is sufficient to warm the entire room. Often, 7-8 sq m (75-86 sq ft) is not enough, so the shower area is included to make it adequate. However, this is usually the homeowner’s preference and must be communicated accordingly. Because often, in the building scope description or standard house plan, only a shower tray without underfloor heating is planned. If the homeowner opts for an upgrade, everything needs to be carefully considered, including the tiled floor, for example. That’s also why this forum exists—to help with these issues.
@Neubau2022 does not have a low-cost general contractor.
Tolentino29 Jul 2022 08:28
There is also a technical reason to avoid it. For walk-in showers, the screed must be installed with a slope. As a result, the minimum coverage over the heating pipes, usually 45mm (1.8 inches), is often no longer met.
I have this in my own home, and the screed had to be done on site for that reason. Whether the minimum coverage was maintained, I do not know and I do not care.
AllThumbs
29 Jul 2022 08:40
Tolentino schrieb:
There is also a technical reason to avoid it. For walk-in showers, the screed must be installed with a slope. As a result, the minimum concrete cover over the heating pipes, usually 45mm (1.8 inches), is often not met.
I have it in my house; the screed had to be installed on-site because of this. Whether the minimum cover was maintained, I don’t know and I don’t really care.
Yep, that argument was also used to reject my request for underfloor heating in the shower back then.
