Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
- Exterior lighting
You see, we decided against the covered terrace. It was initially planned, but then we removed the walls to create a slightly larger living space. We will cover the terrace later with a retractable awning. This way, we have significantly more “free” light in the open-plan living area.
Neubau202220 May 2022 10:28Mahri23 schrieb:
You see, we decided against having a covered terrace. That was part of the original plan. However, we removed the walls to create a larger living area. We will cover the terrace later with a retractable awning. This way, we get significantly more “free” light in the open living space.Yes, we thought about that a lot as well. And the living room, now measuring 27.8 sq meters (measured yesterday with the new laser gadget :-) ), is completely sufficient once the plaster is applied. More space is always possible, of course. The lighting conditions are perfectly fine. Not everything is painted bright yet, and the ceiling is still black (roofing membrane). The living room will probably get a bit brighter. That’s more than enough for us :-)
Neubau202226 May 2022 07:15Do you know the guidelines for how long drying should take? Are there specific values or measurements that need to be met? In the house, the dehumidifiers do not even fill up after 12 hours anymore. The humidity level was 50% this morning.
Neubau2022 schrieb:
Do you know the guideline for how long drying should take? Are there specific values or parameters that need to be met? In this house, the construction dryers don’t even fill up after 12 hours anymore. The humidity level was 50% this morning.Moisture measurement in centimeters (inches) before installing the floor covering. By the way, I had one construction dryer for around 2xx square meters (square feet).
The rest was handled by opening windows.
If the dryers are no longer filling up, turn some of them off.
Neubau202226 May 2022 08:39TmMike_2 schrieb:
Measurement in centimeters (cm) before floor covering.
By the way, I had a construction dehumidifier for 2xx square meters (sq meters).
The rest was done by opening windows.
When the dehumidifiers no longer fill up, turn some off. They now only fill up after 12 hours. The question is whether I should maybe ventilate only twice a day and empty the construction dehumidifiers.
Hausbau 5526 May 2022 09:15In my opinion, using 6 construction dryers was a bit excessive.
