Created on: 16 May 2021 18:56
Acof1978
- Exterior lighting
Floor plan attached.
Grundriss eines Hauses: Wohnzimmer, Küche, Schlaf-/Kinderzimmer, Bad, Flur, Terrasse.
Neubau2022
6 May 2022 20:47
What is the range extension feature on the Fritzbox 7590 ax?
hanse987
6 May 2022 21:14
The AX supports WiFi 6, while the "older" version supports WiFi 5. That is the main difference. WiFi 6 is the newer and theoretically faster standard. It depends on whether you want to use the router for WiFi or rely on external access points for wireless coverage.
There are also two versions of the AX. The older one still has an S0 port, while the newer one no longer includes it. Since S0 is now almost obsolete, this is not a significant loss.
11ant6 May 2022 23:59
hanse987 schrieb:
There are also two versions of the AX. The older one still has an S0 port, while the newer one no longer includes an S0 port. Since S0 is now almost obsolete, this is not much of a loss.
It’s often quite surprising how many multilink cordless phone systems are still in use and prefer to be connected to their own base station rather than operated as GAP handsets. Such a legacy interface isn’t entirely useless.
Neubau2022
9 May 2022 20:46
The first "small" issue came up today. The planner informed me that the ceiling has to be lowered by 11 cm (4.3 inches) instead of 6 cm (2.4 inches) due to the controlled mechanical ventilation system. For us, this is not really a big problem since the ceiling height will still be 2.72 m (8 ft 11 in). However, I find it a bit odd that after signing the contract in October 2021, which specified a ceiling height of 2.77 m (9 ft 1 in) and included the controlled mechanical ventilation, they now say the drywall ceiling drop needs to be 5 cm (2 inches) deeper. I have a meeting scheduled soon with the managing director. I’m curious but also quite relaxed :-)
Neubau2022
10 May 2022 07:24
hanse987 schrieb:
The AX supports WiFi 6, while the "old" model supports WiFi 5. That is the main difference. WiFi 6 is the newer and theoretically faster standard. It depends on whether you want to use the router for WiFi or rely on external access points for wireless coverage.
There are also two versions of the AX. The older one still has an S0 port, the newer one no longer includes an S0 port. Since S0 is now almost obsolete, losing this port is not a big deal.
So does this mean that with the FritzBox 7590 AX I can use all other standards plus WiFi 6?
Mahri2310 May 2022 09:17
Neubau2022 schrieb:
Does this mean that with the Fritzbox 7590 AX I can use all other standards plus WiFi 6?
Correct. This ensures you are well prepared and future-proofed for the coming years.
