ᐅ Poor Wi-Fi in a Newly Built Home Despite Fiber Optic Connection
Created on: 20 Nov 2020 22:31
Tx-25
Tx-25
20 Nov 2020 22:31
Hello. Today, after 6 months, we finally got internet in our new build. I set up the fiber optic connection on the FritzBox 7590 router. For that, I reset the router to factory settings and configured it according to the fiber installation guide. Then I updated it to the latest version. Somehow, the Wi-Fi isn’t as fast as expected. What could be the reason? The router is located in the utility room (ground floor corner) on a cabinet. Our living room is in the opposite corner on the ground floor. There, we have 3 out of 4 bars, sometimes even less. The speed is not particularly good either.
In the upstairs bathroom (directly above the utility room), the connection is practically non-existent. If I go to the upstairs hallway, I get 3 bars. Shouldn’t the signal actually be stronger throughout, even without a repeater?
The fiber modem and the FritzBox are connected by an Ethernet cable I already had. Should this cable be upgraded? Are there any other tips?
The switch for the LAN outlets isn’t connected yet. I still need to order it and install the wiring.
Bookstar
20 Nov 2020 22:34
That’s strange. Since the update that improved performance, we have very good Wi-Fi. Same router. Measure the amount of data you are getting.
T_im_Norden
20 Nov 2020 22:38
How is the connection directly in front of the FRITZ!Box? Otherwise, run a speed test to see how much bandwidth is reaching you.
Tx-25
20 Nov 2020 22:58
These are the details of the Fritzbox.
Internet Connection
IPv4: connected since 20.11.2020, 14:57, Telekom, internet access speed (available bitrate): ↓61.8 Mbit/s ↑12.4 Mbit/s
IPv6: connected since 20.11.2020, 14:57, Telekom, internet access speed (available bitrate): ↓61.8 Mbit/s ↑12.4 Mbit/s
Test internet connection speed?
I will check tomorrow what speed actually comes through and try to switch the phones to the 5 GHz network instead of the 2.4 GHz today. That should help, right?
nordanney
20 Nov 2020 23:03
My VDSL is actually faster...
But for fast Wi-Fi, it's more than adequate (and for everything else as well).
Tx-25
20 Nov 2020 23:57
I just wanted to connect to the 5 GHz network. However, it was even slower than the 2.4 GHz one, so I decided not to use it. Despite fiber optic and the latest technology, this can’t be the ultimate limit.
