Created on: 2 Oct 2017 23:25
R.Hotzenplotz
Hello everyone!
Well then: here’s to the next 500 posts on this project!
R.Hotzenplotz4 Oct 2017 13:3511ant schrieb:
Well then: here’s to the next 500 posts on this project!I find the topic of the parapet height more crucial than the one about the doors.
I have now reported that on the ground floor and first floor, everything except the ground floor front windows should have a parapet height of about 87cm (34 inches) and a window sill top edge of 90cm (35 inches).
Make sure to include the parapet height on your checklist for the final inspection drawing, and then...
Plan the room volumes, then check the window positions, and finally determine the window positions and parapet height. Otherwise, a lot of information tends to get lost in between.
R.Hotzenplotz4 Oct 2017 19:07RobsonMKK schrieb:
What kind of interior window sills do you have that are 3 cm (1.2 inches) thick?The construction specification states 20 mm (0.8 inches) deep and 15 mm (0.6 inches) thick.
