ᐅ IKEA Yttran – The single-lever mixer feels a bit loose – is this normal?
Created on: 2 Mar 2017 17:31
Seoul_6199
Seoul_6199
2 Mar 2017 17:31
we recently replaced our kitchen mixer tap and installed the YTTRAN mixer tap/kitchen, chrome-plated – without pull-out hose.
So far, so good, but there is one question:
Is it normal for the YTTRAN mixer lever, which moves from cold to hot, to have a slight wobble or *play*? The YTTRAN can be moved slightly from side to side when touched and moved sideways. Not much, but noticeable. I have never experienced this with any other faucet before.
We previously had a Grohe faucet, which was only installed for a short time and then sold because it had a relatively high spout that we did not like in hindsight. That mixer lever was firmly fixed with no play.
Can anyone share their experience with this YTTRAN mixer lever?
And a further question:
If I want to replace the YTTRAN faucet, how does that work? I can’t just remove it first and take it to IKEA, can I? Do they give you a faucet first, and then you return the old one within a few days?
Thank you very much for any advice.
IKEA-Freund
3 Mar 2017 09:16
I’m not familiar with Yttran – but the single-lever faucets I know all have a screw that secures the mixing lever to the cartridge (usually a small Allen screw). If this is loose, the top part can wobble. These screws are often hidden under covers (for example, the hot-cold indicator or similar). The Yttran catalog image doesn’t show a cover – maybe there is something on the back side?
Regards,
IKEA-Freund
Seoul_6199
3 Mar 2017 15:59
thank you very much.
That’s exactly how it is, and I had suspected it as well, but wasn’t completely sure.
I had already noticed that at the rear of the mixing lever there is a small chrome-plated metal cover, about 5-6 mm (0.2-0.25 inches) in diameter.
Following your tip, I tried to remove this cover, which wasn’t easy. You had to push it from the inside out underneath the mixing lever with a flat screwdriver.
Then you actually see a small screw behind it, and that must be it. You probably need to tighten it, but I failed at that again…
Because this screw has a special shape and although I have almost all common screwdriver types, I don’t have the right one to properly tighten this screw.
Anyway, the faucet didn’t fully convince us either, so we are returning it to Ikea next week.
We have already ordered a Grohe faucet (design similar to the Yttran), as you know exactly what you get and can rely on it for many years. We previously had a Grohe faucet in the kitchen for a few months, but it had a rather high spout (C-shaped), which wasn’t very practical because it splashed a lot. Then we happened to see and buy the Yttran faucet at Ikea and switched from Grohe to Ikea.
It was a less convincing detour to an Ikea faucet.
In the future, it will be Grohe again, no questions asked.
Thanks again for the advice.
IKEA-Freund
3 Mar 2017 18:13
The screw might require a 2.5mm (0.1 inch) hex key.
Regards,
IKEA-Freund
Seoul_6199
3 Mar 2017 18:22
Tried everything, unfortunately it doesn’t fit.
Allen key, which is always the first thing I try with Ikea products.
But anyway, the faucet will be returned.
In this category, you have to prefer other products for better quality.
Thank you.
fleptin
3 Mar 2017 18:39
It doesn’t matter whether this is normal or not. If the mixing lever is loose, get a different faucet, preferably not from a furniture store.
