ᐅ How do I clean the plastic fronts of Ikea PLATSA units?
Created on: 10 Jul 2024 09:34
Arvin64
Arvin64
10 Jul 2024 09:34
Hello everyone, I recently purchased an Ikea Platsa wardrobe system with white plastic fronts. Since the fronts have a smooth, glossy surface, I am wondering about the best and gentlest way to clean them without scratching or dulling the finish. I am particularly interested in suitable cleaning products and methods for this type of plastic front, for example, whether harsh cleaners should be avoided and if microfiber cloths are recommended. Are there any specific recommendations from Ikea or experiences from the community that could help me keep the fronts clean and in good condition over the long term? Thank you in advance!
Maria35
10 Jul 2024 10:12
For cleaning the plastic fronts of Ikea PLATSA, I recommend the following procedure: - Always use a soft microfiber cloth to avoid scratches. - Use a mild soap solution or a gentle all-purpose cleaner without solvents or harsh chemicals. - Avoid aggressive cleaners such as alcohol, ammonia, or abrasive substances, as they can damage the surface and cause it to appear dull. - Lightly moisten the cloth, apply the cleaner, and gently wipe the fronts. - After cleaning, wipe again with a damp cloth without any cleaner and then dry the surface. This helps prevent streaks. According to Ikea, this method is also recommended for their plastic fronts. This way, the fronts remain visually appealing and retain their protective layer.
Palenar
11 Jul 2024 14:23
I would like to add more detail to the answer, as plastic surfaces like those on Ikea PLATSA fronts have several special considerations. The plastic fronts are usually made of melamine-coated engineered wood or similar composite materials, with a smooth, glossy plastic layer. The key points for cleaning are: - Moisture: Fronts should not be cleaned with excessive moisture, as penetrating water can cause the material to swell. - Cleaning solution: Mild, pH-neutral cleaners are ideal. For example, a mixture of water and a small amount of dish soap. - Tools: Use microfiber cloths or soft sponges, never abrasive pads or brushes with stiff bristles. - Stains: For stubborn stains, isopropyl alcohol can be used carefully, but sparingly and tested first in an inconspicuous area. - Temperature: Avoid hot water, as it could damage the plastic layer. Additionally, I recommend keeping the fronts dust-free regularly, since dust mixed with coarse dirt can quickly cause scratches during cleaning. Since you likely have a combination of matte and glossy fronts, be cautious with the type of cloth and cleaning agent used, as matte surfaces are more sensitive.
fredle
12 Jul 2024 07:58
I have had good experiences cleaning Ikea PLATSA plastic fronts using the following method:
1. Preparation: Thoroughly dust the fronts with a dry microfiber cloth to avoid scratches caused by dirt particles.
2. Cleaning: Prepare a mixture of warm water and a small amount of mild dish soap.
3. Application: Gently wipe the surface with a soft sponge or microfiber cloth, avoiding excessive moisture.
4. Rinsing: Follow up by wiping with a lightly dampened cloth without any cleaning agents to remove soap residue.
5. Drying: Immediately polish dry with a soft, dry cloth to prevent water spots.
Common mistakes I have noticed:
- Using harsh scouring agents or metal sponges that cause permanent scratches.
- Applying too much pressure, which can damage the surface.
- Using alcohol-based cleaners or aggressive chemicals that attack the protective layer.
In summary: Less is more, and especially gentle cleaners are key. By following this approach, the surface has remained in excellent condition for a long time.
Jukin
13 Jul 2024 18:47
Arvin64 schrieb:
I’m especially interested in suitable cleaning products and methods for this type of plastic fronts, for example whether aggressive cleaners should be avoided and if microfiber cloths are recommended.
Yes, microfiber cloths are the best choice for the Ikea PLATSA fronts because they clean gently and do not leave fine scratches.
Maria35 schrieb:
Avoid aggressive cleaners such as alcohol, ammonia, or abrasive cleaners, as they can damage the surface and cause it to become dull.
I can confirm that. From my experience, solvent-based cleaners are a no-go because they harm the finish. I often use just warm water and a mild detergent.
Additionally, for stubborn stains, I recommend gently cleaning with a slightly damp soft-bristled toothbrush to reach corners or hinges without scratching the surface.
One last tip: To keep the fronts shiny for a long time, you can polish them afterwards with a dry microfiber cloth, which brings out a nice shine on the surface.
