ᐅ How do I best care for IKEA Metod cabinet fronts made of melamine?
Created on: 7 Nov 2019 10:13
dimobu
dimobu
7 Nov 2019 10:13
Hello everyone, I’m looking for tips on the best way to care for IKEA Metod fronts made of melamine. These kitchen fronts are very popular because of their durability, but I want to avoid them becoming dull over time or getting damaged from improper cleaning. Specifically, I’m interested in which cleaning products work best and whether there are any special maintenance techniques to prevent scratches, streaks, or discoloration. I’m also curious about whether aggressive cleaners should be avoided and how often they should be cleaned. If anyone has experience, I’d appreciate detailed and practical advice.
sanjon
7 Nov 2019 10:45
I recommend cleaning the fronts with a mild dish soap and a soft cloth. Do not use aggressive or abrasive cleaners, as they can damage the surface. After cleaning, wipe down with clear water and dry thoroughly.
Jonna
7 Nov 2019 11:05
For the care of melamine fronts from the IKEA Metod series, it is important to follow the manufacturer’s instructions. They recommend gentle cleaning with pH-neutral cleaners. Scratches cannot be removed by cleaners, as they usually result from mechanical impact. Regular cleaning after soiling is sufficient. Avoid abrasive sponges or harsh chemicals, as these can damage the surface and cause loss of gloss.
Svenja7
7 Nov 2019 11:47
I would like to add: For stubborn stains, you can use a mixture of warm water and a small amount of vinegar. Vinegar has disinfectant properties and effectively dissolves grease, but it does not damage melamine if used sparingly. It is important to thoroughly wipe the surface with clean water afterward and immediately dry it with a soft cloth. It is also recommended not to use steam cleaning devices, as the heat can damage the coating.
dimobu
7 Nov 2019 13:22
Thanks for the tip! Are there any specific examples of pH-neutral cleaning products commonly found in households? Or are specialized products for kitchen fronts better? Also, I’m curious whether using waxes or polishes to protect the surface is advisable, or if that could be harmful for melamine.
letar
7 Nov 2019 14:01
For clarification: Melamine-coated fronts are durable but not solid wood fronts. Therefore, waxes or polishes should not be used, as they do not provide genuine protection on the smooth surface and can leave residues. For cleaning, neutral, mild all-purpose cleaners that do not contain alcohol or abrasive ingredients are suitable. Highly concentrated natural products such as citric acid or acetic acid should be avoided – small amounts, as described by Svenja7, are acceptable if wiped off immediately.
