ᐅ Are there long-term protection options for IKEA PLATSA furniture?
Created on: 23 Oct 2016 08:12
Jogau45
Jogau45
23 Oct 2016 08:12
Good morning everyone, I have a detailed question: Are there any long-lasting protective options for IKEA Platsa furniture that can effectively prevent common issues like scratches, water stains, and general wear over time? I am particularly interested in whether the surfaces can be treated without compromising the design or functionality, and if such measures are truly sustainable in the long term. If anyone has practical experience or recommendations, I look forward to a thorough discussion.
Lucki
23 Oct 2016 08:47
Hello! I think your question is really important because PLATSA is great, but also quite delicate. I treated my cabinets with special plastic care products and found that it really makes a difference! Of course, you never get 100% protection, but with regular maintenance you can achieve a lot. Personally, I use this plastic polish that keeps the surfaces shiny and protects against water stains. Give it a try, it’s definitely worth it!
Tobias
23 Oct 2016 09:03
When it comes to protection, I recommend sealing with furniture wax or oil. Easy to apply, it enhances resistance to moisture and scratches. Important: Do not apply too thickly to avoid leaving films.
Gerard
23 Oct 2016 10:21
Regarding the main question "Are there permanent protection options for IKEA PLATSA furniture?":
PLATSA furniture is primarily made of coated engineered wood (particleboard with a melamine resin coating). This makes the surface factory-applied relatively resistant to moisture and scratches.
Long-term protection measures focus on:
- Avoiding mechanical stress and scratches by using felt pads under the feet or cushioning when moving the furniture.
- Regular cleaning with mild cleaners; avoid harsh chemicals.
- Occasional aftercare using wax or suitable plastic care products, although their effectiveness and durability are limited.
A permanent, fully protective sealant, like those used for solid wood, is only partially applicable here due to the melamine surface and generally unnecessary, as the surface has already been industrially optimized.
SUPE2
23 Oct 2016 10:45
I would like to add: It is also important not to leave damp items sitting for too long, as this is the best way to prevent water stains. Otherwise, the original coating is durable enough for everyday use.
REN40
23 Oct 2016 12:10
I see it this way: lasting protection mainly depends on how the material is handled. Only limited effectiveness can be expected from technical measures (coatings, waxes). For additional protection, transparent protective films can be applied to the surface, which can be removed without leaving any residue. These films protect against scratches but should be replaced regularly.
