ᐅ How can I gently clean the wooden parts of IKEA PLATSA?
Created on: 7 Aug 2022 09:12
bifinar
bifinar
7 Aug 2022 09:12
Hello everyone, I recently received some wooden parts from IKEA Platsa and now want to clean them as gently as possible without damaging the surface or altering the colors. My wooden parts are mainly made of MDF with a melamine coating, and some have real wood fronts. What cleaning methods would you recommend, especially for everyday dust, fingerprints, or light grease stains? I want to avoid using anything containing harsh chemicals or that could damage the protective layer. Looking forward to your tips!
Blavin
7 Aug 2022 09:48
For gentle cleaning of IKEA PLATSA wooden parts, which are mostly made of melamine and MDF, I recommend using a damp microfiber cloth. This cloth effectively picks up dust without scratching the surface. For greasy stains, a drop of mild dish soap in warm water or special wood cleaners without solvents is sufficient. It is important to wipe the wood dry afterwards to prevent moisture from penetrating and damaging the material. Avoid chemical cleaners containing alcohol or ammonia, as they can damage the protective layer.
rigau
7 Aug 2022 10:03
Microfiber cloth with lukewarm water plus a little mild dish soap. Then wipe dry. No chemicals.
PAREL
7 Aug 2022 11:27
I would like to provide a brief guide on how to properly clean wooden parts of IKEA PLATSA without risking damage.
- Always start by dusting with a dry microfiber cloth, as loose dirt can cause scratches.
- For grease stains or heavier dirt, use lukewarm water with a mild dish soap.
- Do not let moisture sit for too long; the cloths should only be slightly damp.
- After cleaning, immediately wipe again with a clean, dry cloth to prevent water stains and swelling.
- Avoid all aggressive cleaners or abrasive substances, as these can damage the melamine coating.
A common mistake is using too much water or cleaning the wood parts with inappropriate products. This significantly reduces the lifespan of the furniture surface.
bifinar
7 Aug 2022 13:41
PAREL schrieb:
A common mistake is using too much water or wiping the wooden parts with unsuitable products.
That’s a good point. Are there specific recommendations for the ratio of water to dish soap, meaning how much dish soap is actually needed to avoid damaging the surface? Or is just a few drops in a bucket of water enough?
JONSON
7 Aug 2022 14:16
For cleaning painted or melamine-coated furniture surfaces, usually 1-2 drops of mild dish soap in about 5 liters (1.3 gallons) of water is sufficient. It is important that the cloth is only slightly damp, not wet. This prevents water from seeping into the edges and causing the material to swell. For heavier dirt, you can temporarily increase this amount slightly, but you should avoid leaving the furniture wet for an extended period.
