ᐅ How can I clean matte IKEA Metod cabinet fronts without causing damage?
Created on: 14 Sep 2020 08:17
KotammoHello everyone, I recently received a new kitchen with matte IKEA Metod fronts and am now facing the challenge of cleaning them without damaging the matte finish or surface. I am especially interested in methods and products that are effective but do not leave scratches, shiny spots, or other unpleasant residues. Are there any special cleaning agents or home remedies that work particularly well?
Additionally, it would be helpful if you could share experiences with long-term care, as I want to avoid the fronts becoming stained or unattractive over time. Thanks in advance for any helpful advice!
Hello Kotammo, your question about the proper cleaning of matte IKEA Metod fronts is very valid. These are usually lacquered MDF fronts with a delicate surface. For cleaning, I recommend the following:
- A soft microfiber cloth to avoid scratches
- Lukewarm water, possibly with a mild dish soap to remove grease
- No aggressive cleaners or abrasive pads, as they can damage the matte surface
Regular maintenance, about every 1–2 weeks, prevents the buildup of stubborn dirt. Also, wiping off splashes immediately after cooking is helpful, since some substances can bake into lacquered surfaces.
If you are specifically looking for a method to remove grease, deionized water with a small amount of gentle cleaner is the best choice. Please make sure to test it first in an inconspicuous area!
Hello everyone, I would like to add a brief guide for the optimal cleaning of matte lacquered surfaces like those on IKEA Metod:
1. Preparation: Use a clean, soft microfiber cloth whenever possible. Regular cloths can leave lint or slightly damage the surface.
2. Cleaning solution: Add a small amount of mild dish soap to lukewarm water. Avoid abrasive or solvent-based cleaners, as they can damage the surface.
3. Procedure: Lightly dampen the microfiber cloth and gently wipe the surface without pressing or rubbing.
4. Drying: Use a dry microfiber cloth to absorb moisture, ideally immediately after cleaning, to prevent water spots.
5. Stains: For stubborn stains, you can try gently reworking the area with a damp cloth and some cleaning solution, but without scrubbing.
6. Long-term care: Avoid direct heat exposure as well as strong sunlight to prevent discoloration. Regular but gentle cleaning helps to maintain the matte finish.
Typical mistakes include using grease-dissolving chemicals like alcohol or ammonia, which can damage the surface texture.
LuMarcel4314 Sep 2020 10:03RON57 schrieb:
- Do not use aggressive cleaners or abrasive pads, as they can damage the matte surfaceThis is often where the problem lies: many users instinctively reach for strong cleaners, believing that only these can effectively remove dirt. I would even go further and say that some common glass cleaners or all-purpose cleaners containing alcohol can indeed harm the matte finish.
Has anyone had experience with certain products from hardware stores proving to be safe, or should one strictly stick to the recommended mild dishwashing detergents? My guess is that the best approach is to use only pH-neutral cleaning agents.
reoWilhelm14 Sep 2020 10:37LuMarcel43 schrieb:
Does anyone have experience with whether certain products from DIY stores have turned out to be safe, or if you really should only use the recommended mild dish soaps?I'll try to put it humorously: For matte surfaces, the motto is – treat them like a fine wine, not like your car’s paintwork after an off-road adventure! 😉
I often use very gentle cleaning agents without any fuss and haven’t had any problems so far. What helps is an ultra-fine microfiber cloth, which prevents scratches even during the "wine tasting."
So better mild and gentle than scrubbing away enthusiastically.
