ᐅ How can I clean Ikea Metod countertops effectively and gently?
Created on: 8 Jun 2020 09:17
Bekelechi
Bekelechi
8 Jun 2020 09:17
Hello everyone, I recently bought an Ikea Metod kitchen with countertops made of a rather sensitive laminate material. Unfortunately, the surface seems quite prone to stains and scratches, so I’m unsure how to clean the countertops effectively and, most importantly, gently without damaging them or causing the surface to become dull. Could someone please share tips on which cleaning products to use, whether it’s necessary to avoid abrasive cleaners completely, and if there are any special techniques for removing water spots, grease marks, or light buildup? I definitely want to avoid damaging the countertop unnecessarily since it was quite expensive. Thanks in advance for any advice and shared experiences!
joroti
8 Jun 2020 09:38
I would recommend using a mild dish soap with warm water for daily cleaning and wiping the surface with a soft cloth. You should avoid harsh abrasive cleaners, as they can damage the laminate coating.
Guyju
8 Jun 2020 10:02
Hello, to answer your question in more detail, here is a brief guide:
- Daily cleaning: Use a soft microfiber cloth with lukewarm water and mild dish soap. Do not use a coarse sponge or abrasive cleaners.
- Removing stains: Light greasy marks can be wiped off easily with a cloth dampened in vinegar water (1 part vinegar, 3 parts water), then rinse with clear water.
- Tough residues: If necessary, you can gently use a plastic scraper – metal is not allowed to avoid scratches.
- Avoid aggressive cleaners containing alcohol, abrasives, or bleach; they will definitely damage the surface.
In summary: Gentle handling and mild products keep the surface looking good for a long time.
rubybi
8 Jun 2020 10:28
Good question! I have a Metod countertop myself and make sure to use only mild cleaning agents. It is also important to always dry the countertop well after cleaning, as standing water can leave unpleasant stains. For tougher stains, I use a damp cloth with a little baking soda – it acts as a gentle abrasive without scratching the surface.
- Never use coarse sponges or steel wool.
- Prefer cleaning products without harsh chemicals.
I have also found that regular cleaning prevents stains from setting in.
batabe
8 Jun 2020 11:05
Hello Bekelechi, I completely understand your concern. The Ikea Metod countertops are usually coated with melamine or laminate surfaces, which are resistant to everyday wear but not indestructible. For cleaning, you should keep the following in mind:
- Always use soft cloths or sponges.
- Avoid harsh cleaners and abrasive products.
- Grease can be effectively removed with warm water and mild dish soap.
- For water spots, simply wiping and drying with a clean, soft cloth often helps.
If stubborn stains do occur, avoid scrubbing aggressively. It’s better to soak the dirt, for example with a damp cloth and dish soap, and then gently wipe it away.
To protect the surface, you can occasionally use special laminate cleaners if available.
I hope this helps you!
Renegi
8 Jun 2020 11:47
I clean my Metod countertop only with warm water and a soft cloth. Everything else has quickly left streaks or dull spots. Only for very stubborn stains do I add a drop of dish soap.
