ᐅ How can I clean IKEA Metod kitchen countertops without scratching them?
Created on: 17 Oct 2021 08:12
Masipi
Masipi
17 Oct 2021 08:12
A few months ago, I installed an IKEA Metod kitchen countertop and I am very satisfied with the design and durability. However, I am concerned about the proper cleaning method because I want to avoid unsightly scratches on the surface.
My question is: How can I clean IKEA Metod kitchen countertops effectively and gently to prevent any scratches? Which cleaning products and tools are suitable, and what should definitely be avoided? The instructions only provide very general advice, so I would appreciate your experiences and tips.
Thank you very much in advance for your help!
Laukau5
17 Oct 2021 08:46
Hello Masipi,
That is a very good and important question, especially for countertops that are used daily. IKEA Metod countertops are often coated with a melamine resin layer, which is durable but can still be scratched or damaged if not treated properly.
My cleaning recommendations are as follows:
- Avoid abrasive cleaners or steel wool, as these can permanently damage the surface.
- Instead, use soft cloths, preferably microfiber cloths, to wipe the countertop.
- For everyday dirt, a damp cloth with a little mild dish soap is sufficient.
- For tougher stains, you can use a mixture of water and vinegar in a 1:1 ratio, but be careful, as too much acid can cause damage over time.
How often do you clean the countertop, and do you encounter any particular stains? For example, stubborn coffee or grease marks?
Masipi
17 Oct 2021 09:10
Laukau5 schrieb:
How often do you clean the countertop, and do you sometimes encounter stubborn stains? For example, tough coffee or grease marks?
Thanks for the quick reply! I usually wipe the countertop daily, mostly with a damp cloth and occasionally some all-purpose cleaner. So far, the stains have mostly been greasy splashes from cooking or sticky sugary residues from drinks. I haven’t had many hard or dried-on stains yet, but that might still happen.
I also wanted to ask if there is a specific order or technique to follow when cleaning to avoid creating micro-scratches? Sometimes you hear that wrong movements can damage the surface more easily.
Laukau5
17 Oct 2021 09:58
Masipi schrieb:
I also wanted to ask if there is a specific order or technique to follow during cleaning to avoid creating micro-scratches?
Yes, definitely! To avoid micro-scratches, you should always start with the gentlest method and only move to stronger ones if necessary. Specifically:
- Never use abrasive sponges or scouring pads directly, even if it’s tempting.
- Always begin with a soft, damp microfiber cloth.
- Wipe gently in one direction, not in circular motions, to minimize stress on specific spots.
- For tougher stains, use a soft cleaning pad that is not abrasive.
- After cleaning, dry the surface with a clean, dry cloth, because dust particles combined with moisture can also cause scratches.
Additionally, be careful not to have sharp objects on the surface during cleaning, such as razor blades, sharp knives, or stiff brushes.
What exactly is the countertop material? Do you have a special surface, for example, a matte or glossy finish?
Masipi
17 Oct 2021 10:26
Laukau5 schrieb:
What exactly is the worktop like? Do you have a specific surface, for example, a matte or glossy finish?
The board is a white, matte version with a melamine resin coating, not a glossy surface. I suspect that the matte coating might be more sensitive, especially to small scratches, so I am being particularly careful here.
Layla
17 Oct 2021 10:54
I can really relate to Masipi here. Some time ago, I had a similar countertop and was unsure how to clean it properly. What helped me was regularly cleaning the surface with a special mild kitchen cleaner designed for coated furniture, always using soft cloths.
It’s also important not to scrub too hard, as the matte finish has tiny textures that can easily get damaged.
For me, a mixture of warm water and a little dish soap works well for most stains. If a stain is more stubborn, I let the solution sit for about a minute before gently wiping it off.
It might feel a bit slow, but this is the best method for protecting the countertop in the long run.
