Hello everyone, I have a somewhat special request: Some minor damage has appeared on a few of the countertops in my IKEA Metod kitchen – including small scratches and slightly swollen spots on the surface. Since the Metod countertops are usually made of coated wood-based material with melamine resin, I’m wondering how I can efficiently and permanently repair such damage myself. I don’t want to replace the entire countertop, as that would be a lot of effort. Does anyone have experience with suitable repair materials, techniques, or specific methods to treat both scratches and areas with slight moisture damage? It would be great if you could share tips that provide not just a quick patch-up but a durable solution. Thanks in advance!
Hello Oskar, thank you for your detailed question! IKEA Metod countertops are usually made of laminated particleboard or coated MDF panels. Small scratches can often be repaired using special furniture repair wax that is color-matched to the surface. It is important that the area is clean and free of grease before you begin. For swollen spots, which are usually caused by moisture, I recommend thoroughly drying the area first. After that, the swollen sections can be gently smoothed with fine sandpaper (400 grit) and minor irregularities can be filled with repair filler. Finally, protect the surface with an appropriate paint or clear coat. There are also so-called melamine contact adhesives that are specifically suitable for repairing damaged laminate spots. You should avoid soaking the countertop too much to prevent further damage. Let me know if you need more details on any of the steps!
If the issue is swollen spots, you should definitely check whether moisture is still present in the material. Drying with a hairdryer on the lowest setting or allowing the area to air dry for a longer time works best. When sanding, be careful to only work on the raised surface so that the foil covering remains as intact as possible. For filling in, a fine ceramic putty knife is recommended—but only if the repair area is completely dry to prevent later detachment.
I can understand how frustrating it is when countertops get damaged, especially when you want to use them for a long time. I once had small scratches on my Metod cabinets and chose to use furniture wax. It gave me the feeling that the repair was truly “made for me” and not just a quick fix. I also found it important to treat the area gently after the repair to avoid causing new damage. So: patience and the right materials make a big difference.
