ᐅ What type of protection should I consider when using Ikea Metod countertops?
Created on: 24 Oct 2018 18:03
peo-to
peo-to
24 Oct 2018 18:03
Hello everyone, I am planning to get an Ikea Metod kitchen and have now reached the stage of choosing countertops. Since Metod countertops are often made of coated wood-based materials, I wonder what specific protection I should consider during use to ensure they last as long as possible. What care instructions are useful? Are there any special treatments or protective measures I need to apply to the surface to minimize damage from water, heat, or scratches? I would appreciate tips based on experience or expert knowledge!
Espen
24 Oct 2018 18:17
Mainly, water should be avoided on Metod countertops, especially standing water at the edges. It is best to use coasters and cutting boards. Pot holders help protect against heat.
meoka
24 Oct 2018 19:02
I’ll address this in more detail, as Ikea Metod panels usually involve either melamine-coated or laminate countertops:
- Water: Make sure that especially the edges always stay dry, as this is where the bond between the engineered wood and the coating is most vulnerable. Standing water can cause swelling.
- Heat: Direct heat from hot pots or pans can quickly damage the surface. Always use trivets or oven mitts.
- Scratches: Use cutting boards. Cutting directly on the countertop leaves unsightly scratches that cannot be repaired.
- Cleaning: Avoid harsh cleaning agents and abrasive sponges. A soft cloth with mild dish soap is sufficient.
Summary: Protection mainly involves mechanical (cutting boards), thermal (oven mitts), and moisture protection at the edges.
JUHAU
24 Oct 2018 19:15
I would add: Avoid prolonged exposure to moisture at the cut edges, especially if the board comes into contact with water, as the material can otherwise swell.
peo-to
24 Oct 2018 19:38
Thanks, that makes sense. Is it still possible to repair or at least conceal superficial damage using home remedies or special care products? Or is the material too sensitive for that?
lechen
24 Oct 2018 19:55
Small scratches can usually be reduced somewhat with polish or wax, but a proper repair is nearly impossible with melamine boards. For more extensive damage, the board usually has to be replaced.
