ᐅ How can I clean IKEA Metod kitchen countertops without scratching them?
Created on: 17 Oct 2021 08:12
Masipi
A few months ago, I installed an IKEA Metod kitchen countertop and I am very satisfied with the design and durability. However, I am concerned about the proper cleaning method because I want to avoid unsightly scratches on the surface.
My question is: How can I clean IKEA Metod kitchen countertops effectively and gently to prevent any scratches? Which cleaning products and tools are suitable, and what should definitely be avoided? The instructions only provide very general advice, so I would appreciate your experiences and tips.
Thank you very much in advance for your help!
TAUPLO
17 Oct 2021 11:31
Layla schrieb:
It’s also important not to scrub too hard, because the matte surface really has tiny irregularities that can easily get damaged.
Exactly! It’s easy to start scratching without meaning to. I always use soft cloths, preferably microfiber towels, and very importantly: don’t use harsh chemicals! A little dish soap and warm water is usually enough.
And honestly: the kitchen countertop isn’t made for polishing, but for cooking! So if there’s a stain that doesn’t come off right away, just be gentle and take your time.
Tommy38
17 Oct 2021 13:03
Hello Masipi,
I would like to add that you should definitely avoid certain things when cleaning:
- Do not use harsh or abrasive cleaning agents such as bleach or ammonia.
- Avoid abrasive creams, steel wool, or hard scouring pads.
- Stay away from strongly alkaline cleaners.
For cleaning, I recommend:
- Using a soft microfiber cloth or cotton cloth
- Warm water with a mild dishwashing detergent
- For tougher stains, let the solution sit briefly before gently wiping it off
Finally, dry the surface thoroughly to prevent water spots and limescale marks.
If you feel that the surface looks dull, be careful, as aggressive cleaners can damage the protective layer.
Rhett
17 Oct 2021 15:15
Short and precise:
- Soft cloth
- Mild dish soap
- No abrasive cleaners
- Do not rub, gently wipe instead
- Wipe dry immediately
laureo
17 Oct 2021 16:42
I can only emphasize the advice regarding cleaning agents. Additionally, after consulting with a kitchen specialist, I received the following tips:
- A slightly damp microfiber cloth is ideal.
- If you have stains that cannot be removed by normal wiping, you can use a mixture of 70% water and 30% isopropyl alcohol; it evaporates quickly and barely affects the coating.
- Under no circumstances use aggressive solvents like acetone or turpentine.
Important: Do not let cleaning agents sit on the surface for too long to avoid material damage.
Masipi
17 Oct 2021 17:20
laureo schrieb:
If you have stains that cannot be removed by normal wiping, you can use a mixture of 70% water and 30% isopropyl alcohol, which evaporates quickly and hardly affects the surface coating.
That’s a very interesting tip, thank you! I’m just wondering if the countertop might still get damaged when using alcohol, especially if it’s left on for a longer time. Do you have any experience or specific recommendations on how long the cloth with the solution should remain on the surface?
laureo
17 Oct 2021 18:06
Masipi schrieb:
I’m just wondering if the countertop might still get damaged from the combination of alcohol and prolonged exposure.
Good question! Isopropyl alcohol is often used for cleaning because it evaporates quickly and is relatively gentle. Still, I would never leave a wet cloth on the countertop for more than 30 seconds. Instead, lightly moisten the cloth, wipe briefly, and immediately follow with a dry cloth.
Long-term effects are manageable as long as you don’t flood or scrub the countertop excessively afterward. The key is to use the product sparingly and avoid any pooling.
