ᐅ Effectively Cleaning IKEA Metod Countertops Without Scratches
Created on: 28 Mar 2022 07:32
TogusanHello everyone,
Some time ago, I installed the countertops from the IKEA Metod kitchen and now want to clean their surface in the long term as effectively and, above all, scratch-free as possible. According to the manufacturer, the surface is melamine-coated, which means it has a smooth and durable finish.
My question to the community: Which cleaning agents and methods would you recommend for thoroughly removing everyday dirt (grease, water stains, light crumbs) without scratching or damaging the surface seal? Are there any specific no-nos or home remedies that should be avoided? And if so, why?
I would appreciate any technical details or experiences with special cleaners or care products.
When cleaning IKEA Metod countertops with a melamine surface, abrasive cleaners should be strictly avoided as they can damage the finish. It is recommended to use mild, pH-neutral cleaning agents or simple dishwashing solutions.
- Grease stains can be effectively removed with warm soapy water.
- Water stains caused by mineral deposits disappear after cleaning and thorough drying.
- Avoid abrasive sponges; instead, use soft cloths or microfiber towels.
I would also recommend avoiding vinegar-based cleaners or alcohol-containing cleaners, as they could dull the surface over time.
Hello Togusan,
to clean IKEA Metod countertops effectively and without scratching, it is important to treat the surface gently. I usually proceed as follows:
- First, I remove coarse dirt and crumbs with a dry, soft cloth.
- For grease and other stains, I use lukewarm water with a mild dish soap.
- Afterwards, the surface is always wiped with a damp, clean cloth.
- Finally, the countertop is dried with a dry cloth to avoid water spots.
Definitely avoid abrasive cleaners, steel wool, or hard brushes. The melamine surface can be scratched quickly by these materials. If there are tougher stains, I recommend using special cleaners for plastic surfaces that are free of solvents and abrasives.
Important when cleaning melamine-coated Metod countertops is to avoid using solvents such as acetone or harsh chemicals. These can damage or discolor the surface.
A mixture of warm water and dish soap is sufficient to effectively remove dirt. For stubborn stains, a cleaning sponge with a very fine abrasive can be used, but always test it first on an inconspicuous area.
Regular wiping after each use also prevents buildup and helps maintain the surface’s like-new condition for longer.
