ᐅ How can Ikea Pax wardrobes be securely and stably fixed to the floor?
Created on: 4 Nov 2016 08:17
Lafekeo
I am considering installing an Ikea Pax wardrobe in my home, but I have concerns about its stability and safety on my existing floor. My question is how to securely and firmly fix an Ikea Pax wardrobe to a mostly smooth, slightly delicate floor – for example, laminate or tiles – to prevent it from tipping over or sliding, especially when it is fully loaded. Are there specific fixing methods or materials I should use to ensure optimal stability without damaging the floor? What experiences do you have, and what solutions would you recommend?
FABIAN_DEO6 Nov 2016 10:12Franklin36 schrieb:
A common mistake is neglecting wall mounting, which can lead to dangerous tipping.Exactly, that’s the key point with larger cabinets like Pax. I would like to add that the appropriate type of anchor for wall mounting should not be underestimated – there are significant differences depending on the wall type. For a solid concrete wall, you use different anchors than for a lightweight drywall (plasterboard) wall. In the latter case, it’s essential to use special hollow wall anchors.
GIPAPO schrieb:
I fixed the tiles and the Pax cabinet with the original wall brackets. Additionally, I placed thin cork pads under the feet.Using cork is a good idea since it protects the floor well and also provides anti-slip properties. It’s important that the cork pads are not too thick, so the adjustable feet can still function properly. My recommendation:
- Use the original wall mounting with suitable anchors
- Align adjustable feet correctly
- Cut cork or rubber mats thinly and precisely to fit
Taken together, this results in a secure, stable, and floor-friendly installation.
