ᐅ Is there a guide for assembling IKEA Pax wardrobes on sloped ceilings?
Created on: 29 May 2024 08:07
dobajo
dobajo
29 May 2024 08:07
I am currently facing the challenge of assembling an Ikea Pax wardrobe in a room with a sloped ceiling. The standard assembly instructions for Pax are quite clear, but I am wondering if there is a special guide or at least detailed advice on how to install Pax wardrobes safely and securely in sloped ceilings—especially when the wardrobe height needs to be adjusted to fit the slope or when cutting the side panels or shelves is required.
Does anyone have experience with Pax wardrobes in sloped ceilings, know of an official guide, or at least practical methods? I am particularly interested in the question of wall mounting, as the sloped ceiling presents a specific challenge there. Thanks in advance!
fredle
29 May 2024 09:16
Hello dobajo,
Your question is very relevant, as assembling a Pax wardrobe in a room with a sloped ceiling is definitely more complex than in a standard room. To my knowledge, Ikea does not provide an official manual specifically addressing sloped ceilings. However, Ikea offers modular components that allow you to adjust the height to match the slope.
Here is my structured advice for such a project:
- Measure the slope carefully, especially the height at the lowest and highest points.
- Choose the appropriate Pax doors (sliding doors are often better because they take up less space next to sloped walls).
- You can cut the frame parts to fit the slope, but only with proper tools and great care.
- For wall mounting, it is crucial to secure the wardrobe to solid, load-bearing points, since the sloped wall usually does not have vertical surfaces. Therefore, use angle brackets attached to the back of the frame and fix these horizontally to the sloped ceiling.
A common mistake is making adjustments too quickly and inaccurately—better to measure several times and trim step by step.
If you have any specific questions about the individual assembly steps, I’m happy to help further.
pikin
29 May 2024 10:24
fredle schrieb:
As far as I know, there is no official Ikea guide that specifically addresses sloped ceilings.
That matches my knowledge. Ikea does not offer specific instructions for assembling the Pax wardrobe system specifically on sloped ceilings. However, the system can be adjusted modularly.
From a technical perspective, you need to consider the following:
- The cabinet height must be precisely aligned to the slope to ensure optimal stability.
- The frames may need to be shortened from below. Make sure not to damage any load-bearing connectors.
- Wall mounting should be done using special brackets that are mechanically strong and secure even on uneven or angled wall surfaces.
- If possible, add extra braces or shelves to improve stability.
A practical recommendation: Use a spirit level and protractor to check each step carefully.
PeoDaniel
29 May 2024 11:05
dobajo schrieb:
Does anyone have experience with Pax wardrobes in sloped ceilings, or know of any official guidelines or at least practical approaches?
I installed a Pax solution under a sloped ceiling myself two years ago. There are no official instructions from Ikea, but with some basic carpentry skills, it can be done reliably:
- I adjusted the height of the wardrobe at the lowest point of the slope by cutting the sides of the frame to size with a jigsaw.
- The back panel was completely removed and replaced with a custom plywood board, which is sturdy and shaped to fit the slope.
- For wall mounting, I used brackets installed perpendicular to the slope.
- Some doors were trimmed, or I selected special doors without a top edge.
The key is to measure very precisely and not try to ignore the slope by just mounting it as is. Would you like more details about the tools or the necessary measurements?
dobajo
29 May 2024 13:42
fredle schrieb:
I recommend using angle brackets, which you attach to the back of the frame and secure transversely to the roof slope.
That sounds very practical. What material and screws did you use for the brackets? My wall is made of a combination of drywall and timber studs.
PeoDaniel schrieb:
The back panel was completely removed and replaced with a custom-made plywood sheet that is both sturdy and shaped to fit the slope.
Did you make the panel yourself or purchase it ready-made? I ask because I have some concerns about the cabinet’s stability without a back panel. Thank you!
Dilen
29 May 2024 15:11
Technically, there is no official Ikea Pax instruction for sloped ceilings, as the system is designed for standard installation.
The slope of the ceiling requires two main adjustments:
- Mechanical modification of the frame components through professional cutting with suitable power tools. Caution is necessary here, as the stability largely depends on the correct supporting structure.
- Reinforced wall mounting: Use heavy-duty anchors and reinforce the screw connections with bracket supports that can handle both angled and vertical loads.
For proper execution, I recommend following these steps:
1. Measure the ceiling slope with a laser angle meter.
2. Create a CAD drawing of the cut frame.
3. Use a circular saw with a guide rail for precise cuts.
4. Check the seal and angles with a spirit level and protractor.
5. Use plywood or MDF boards for the back panel, adapted to the slope.
I have one question for the original poster: What is the maximum installation depth you have available at the lowest point? This will determine the door and cabinet options.
