ᐅ How can Ikea Pax wardrobes be securely and stably fixed to the floor?
Created on: 4 Nov 2016 08:17
LafekeoI am considering installing an Ikea Pax wardrobe in my home, but I have concerns about its stability and safety on my existing floor. My question is how to securely and firmly fix an Ikea Pax wardrobe to a mostly smooth, slightly delicate floor – for example, laminate or tiles – to prevent it from tipping over or sliding, especially when it is fully loaded. Are there specific fixing methods or materials I should use to ensure optimal stability without damaging the floor? What experiences do you have, and what solutions would you recommend?
FABIAN_DEO4 Nov 2016 08:45To securely and stably fasten Ikea Pax wardrobes on smooth floors, it is important to consider some technical details and requirements. First, check whether the wardrobe already includes the supplied wall fixing brackets – these are usually essential for safety. They prevent tipping under load.
As a next step, I would recommend placing special anti-slip mats on the floor to hold the wardrobe firmly in place and prevent slipping without damaging the surface. These mats are often made of rubber or foam rubber and can be matched to the type of flooring material.
It is also important to adjust the wardrobe’s feet correctly to compensate for any unevenness – Ikea provides adjustable feet for this purpose. However, I wonder what type of floor you have exactly: laminate, tiles, or something else? This significantly influences the choice of fixing materials.
Do you already have a wall to which the wardrobe can be secured? Because wall fixing is the safest protection against accidents, especially with children.
Franklin364 Nov 2016 11:22Here is a step-by-step guide on how to securely anchor your Ikea Pax wardrobe on a smooth floor:
- Check if the wall mounting kit is included in the package. If not, be sure to get one.
- First, choose the right location, ideally against a solid wall.
- Use rubber mats or non-slip felt pads under the wardrobe feet. These prevent both scratches and slipping.
- Adjust the adjustable feet so that the wardrobe stands level on the floor. This is especially important on laminate or tile floors.
- Securely attach the wardrobe to the wall, preferably using anchors and screws suitable for the wall type (e.g., heavy-duty anchors for concrete, specialized drywall anchors for plasterboard).
A common mistake is neglecting the wall mounting, which can lead to dangerous tipping. Another tip: on soft flooring, you can place wooden boards underneath to increase stability. If you like, you can describe your wall and floor situation in more detail, and I can provide more specific advice.
My recommendation for securing an Ikea Pax wardrobe on sensitive flooring:
- Always use the included wall fixings, as these are essential to ensure long-term stability and safety.
- Use rubber pads or anti-slip felt gliders under the feet to prevent slipping and protect the floor.
- For laminate or parquet flooring, make sure no moisture gets underneath the materials to avoid damage.
- Fix screws as close to the floor as possible; for walk-in wardrobe solutions, an additional baseboard can be placed underneath to provide extra stability.
These measures are necessary because Ikea Pax wardrobes, due to their size and height, can become dangerously unstable even under light loads. A combination of wall fixing and floor-protecting anti-slip techniques works best.
