ᐅ How stable is the Ikea PAX wardrobe against tipping over?
Created on: 7 Jul 2023 09:17
Sejepin
I am planning to get an IKEA PAX wardrobe but am unsure how stable this system really is in terms of the risk of tipping over.
Intuitively, I consider the wardrobe to be relatively sturdy, but I have read several warnings emphasizing that tall, slim furniture like the PAX should be securely anchored against tipping.
Therefore, I am interested in how well the PAX is protected against tipping. Is the included wall mounting hardware sufficient? Are there additional tips or proven methods to further improve stability, especially if you have children or place the wardrobe on carpet?
A concrete assessment based on personal experience or technical details would be very helpful. I look forward to your opinions!
JONSON
7 Jul 2023 13:02
As an addition:
IKEA usually provides stabilizing braces (back panels) that further reinforce the cabinet.
It is also important to tighten all screws carefully and not to overlook the wall mounting.
For families with children, additional safety measures such as door locks are recommended to prevent accidental tipping when opening.
U
uslis47
7 Jul 2023 13:55
Hello!
I would like to add that it is advisable to assemble the PAX on a flat surface. Especially if the floor is uneven, using small wooden wedges or adjustable furniture feet can help improve stability.
Additionally, most problems occur when the wardrobe is overloaded or when heavy items are stored on the upper shelves—particularly if there are children in the household.
Therefore, securing the unit to the wall is not optional but essential. When this is taken into account, the PAX is actually very safe against tipping over.
If anyone is unsure, an additional safety measure can be installed at the top edge, such as metal brackets or special furniture straps.
koduga
7 Jul 2023 14:20
I completely understand your concerns about stability, especially when children are around. I felt the same way.
At first, I was unsure and therefore secured all the PAX wardrobe units to the wall in our house, even though I often read that this is only officially recommended.
Doing this gave me a lot of peace of mind, and I really feel safer.
At the same time, I deliberately made sure to store heavier items in the lower and middle sections and only place lighter things at the top.
My advice is to take the fixings seriously!
Sejepin
7 Jul 2023 15:02
noge58 schrieb:
I even installed extra wall anchors to be sure.
Lucien schrieb:
The mounting is done either with small brackets or clamps that secure the cabinet to the wall at the top.
Thanks for the detailed information! How does it work with multiple cabinet units—when placing two or more PAX elements side by side? Is each unit fixed individually to the wall, or can they be anchored together to provide extra stability?
I’m asking because I’m planning a rather wide wardrobe wall and am unsure whether the risk of tipping increases or decreases when the units are connected.
Lucien
7 Jul 2023 15:40
Sejepin schrieb:
What about the versions with multiple cabinet units – like when placing two or more PAX elements side by side?
For multi-unit constructions, each module should be secured individually to the wall.
This prevents individual units from shifting and contributes to the overall stability.
Additionally, the units can be connected to each other, which further reduces the risk of tipping.
IKEA provides guidance in the assembly instructions on how to join and secure the modules.
The risk of tipping does not decrease with the overall width of the setup; as long as the safety fixtures are properly installed, stability is maintained.
PULAU
7 Jul 2023 16:15
Sejepin schrieb:
I’m asking because I’m planning a rather wide wardrobe unit and I’m not sure if the potential risk of tipping increases or decreases when the modules are assembled together.
A wide combined unit is often even more stable, as the individual PAX components can support each other laterally. However, proper wall anchoring of all modules remains important.
Using connection fittings between modules can also stiffen the overall structure.
If you load the modules unevenly, the risk of tipping for individual segments may increase, so balanced loading is recommended.
