ᐅ How do I check the stability of the Pax wardrobe after assembly?
Created on: 25 Sep 2023 08:37
Steffen31
I just assembled my new Pax wardrobe and want to make sure it is truly stable after assembly, with no risk of tipping or wobbling. The assembly instructions are okay, but I didn’t find any specific advice on how to check its stability.
My question to you is: What is the best way to test the stability of a Pax wardrobe on site after assembly?
I am particularly interested in steps I can take right there without having to use extra tools or specialized measuring equipment to detect twisting, tipping risk, or loose fastenings.
Are there any tried-and-true routines or tests you can recommend?
Thank you in advance!
Curtis
25 Sep 2023 12:12
Steffen31 schrieb:
Do you think it's too risky without wall mounting?
In short: Yes.
Wall mounting is not only required but also effectively prevents tipping. Even if the wardrobe seems stable on its own, a minimal force can cause it to tip over if it is not secured to the wall.
Without this safety measure, the Pax wardrobe is fundamentally unstable, especially in homes with children or active environments. I would not take that risk.
Ensuring that your wardrobe is anchored to the wall is the most important step for safety.
tutan
25 Sep 2023 12:40
Curtis schrieb:
Making sure your cabinet is anchored to the wall is the most important step for safety.
Exactly! Even though we often use a casual tone in this forum – safety is the top priority! Believe me, wall anchoring is not just a bureaucratic step; it saves lives and prevents unwanted cabinet movements 😄.
When installing the anchors, take your time to choose the right anchors – not all floors or walls are the same! Laminate usually means a subfloor of wood or screed, so use an anchor suitable for the wall materials.
After that, you can shake the side wall all you want. If nothing wobbles or creaks, everything is good to go.
pa-wolf
26 Sep 2023 07:52
Brief and to the point:
- Tighten all screws
- Secure the back panel properly
- Fix the cabinet to the wall
Only this way is stability reliably ensured.
Matthewt48
26 Sep 2023 08:10
tutan schrieb:
When installing the fixtures, take your time to choose suitable anchors – not every wall is the same!
Good advice! For example, with drywall (plasterboard) walls, you need special cavity anchors; otherwise, the fixture won’t hold. My recommendation: if you’re unsure, test with light loads first or consult a hardware store expert.
Also, remember not to overtighten the screws, as this can damage the material or cause the screw to strip.
GiRoyce
26 Sep 2023 09:29
I also initially assembled a Pax without wall anchors, and it was quite wobbly. After installing the wall brackets and double-checking the screws, the wardrobe became so stable that it barely moved.
Additionally, you can level the wardrobe by adjusting the feet, if available, which makes a difference on uneven floors.
In general: check everything step by step, and safety is guaranteed.
