ᐅ How can I securely install Ikea PAX wardrobes on a tiled floor?
Created on: 18 Jun 2015 10:12
Lopuzar
Lopuzar
18 Jun 2015 10:12
Hello everyone, I plan to install an Ikea PAX wardrobe system in my apartment. The floor is made of glazed tiles, which are somewhat uneven in places. My main concern is secure installation, especially regarding stability and the risk of the wardrobe tipping over. How can I best mount the PAX on a tiled floor without damaging the tiles and still achieve a secure anchoring? Are there any special fastening techniques you would recommend, or perhaps tips for protecting the tiles during installation? Thank you in advance for your advice!
harold
18 Jun 2015 10:47
Hello Lopuzar,
You bring up an important topic: installing PAX wardrobes on tiled floors can be tricky because tiles are delicate and can easily crack. Here is my suggestion in a few steps:
- First, check if your PAX model requires wall anchoring – this is essential for stability.
- Avoid drilling into floor tiles if possible, as the risk of cracking is high. For securing the base, rubber mats or feet, or felt gliders are recommended. These distribute the weight and prevent direct pressure on the tiles.
- For wall mounting: use appropriate wall anchors (e.g., expansion anchors for concrete walls), with at least 2, preferably 3 attachment points.
- If you absolutely need to fix the unit to the floor, sealing and drilling with special ceramic drill bits is possible but carries risk. Alternatively, place a thin wooden or rigid foam board underneath to level out irregularities and keep the wardrobe stable.
In summary: anchoring to the wall is mandatory to prevent tipping. Floor protection via rubber mats safeguards the tiles and distributes loads. Be very cautious when drilling into tiles or avoid it altogether.
dinano
18 Jun 2015 11:19
harold schrieb:
You should generally avoid drilling into floor tiles because there is a high risk of cracking.
This assessment is basically correct, but I think it’s not necessary to rule out careful drilling from the start.
With the right drill bit (diamond or carbide-tipped bits designed specifically for tiles) and a patient hand, the risk can be minimized. However, it’s important to ensure the drill bit doesn’t wobble and to use firm guidance.
I would recommend practicing on a hidden spot or a spare tile before the final installation. This builds confidence, and in case of mistakes, you won’t have any visible damage.
For anchoring, it’s also advisable to install wall plugs deeply and securely, considering the floor more as a secondary fixing point.
DINASAN
18 Jun 2015 11:55
To ensure the safe installation of IKEA PAX wardrobes on tiled floors, I would like to add some technical details, as the complexity of the installation is often underestimated.
First, it is crucial to understand the load-bearing points of the wardrobe. For PAX units, the center of gravity is usually positioned higher due to the dimensions and contents. This means that a secure wall anchoring is absolutely essential. Without these wall brackets, the entire structure can become very unstable.
Regarding the floor: tiles can be sensitive to point loads. Therefore, I advise against drilling directly into tiles unless you use specialized drill bits and are able to avoid cracks by applying appropriate joint mortar or silicone.
My recommendations:
- If you must secure the wardrobe to the floor as well, place a thin leveling plate made of marble or granite tiles, rigid foam, or load-resistant MDF panels under the feet. This will distribute the weight over a larger surface area.
- There are specially designed wardrobe feet with rubber coatings that provide slip resistance and protect against scratches.
- Use a spirit level repeatedly during installation to check the horizontal alignment of the PAX.
If possible, please provide more information about your wall type (drywall, concrete, brick), as this also affects the choice of plugs and screws.
dachen
18 Jun 2015 13:08
DINASAN schrieb:
If possible, please provide more details about the wall construction (drywall, concrete, brick)
This is a crucial point. Without precise information about the wall, any installation recommendation is only half reliable. For drywall, for example, you will need special cavity anchors or, preferably, a different fastening method.
Furthermore, I would add that even with solid walls, load distribution remains critical. Tiles can be brittle, especially if the substrate is not fully even. Irregularities can cause stress when supporting heavy furniture.
Do you have a baseboard, or are you planning to install the PAX unit flush against the wall with minimal clearance? If the baseboard will remain, you should consider it during installation, as it can complicate the mounting.
harold
18 Jun 2015 14:57
A brief addition to the previous posts: the question of substrate preparation is particularly important.
- Before starting installation, check the tiled floor for unevenness using a straightedge.
- Minor unevenness can sometimes be compensated using adjustable furniture leveling feet.
- When drilling into tiles: always use a drill bit at the lowest speed and apply light pressure.
- Depending on the cabinet height, you should use at least two attachment points on the wall to minimize the risk of tipping.
- If you have a baseboard, you might consider removing it to allow for a more even installation or use shimming underneath.
Overall, floor fixation on tiles is of secondary importance. The focus should be on wall mounting plus slip-resistant protection using sealing mats or felt.
