ᐅ What tools do I need to assemble the Ikea Pax wardrobe?
Created on: 12 Oct 2020 17:48
Ronki4
Ronki4
12 Oct 2020 17:48
Hello everyone, I recently ordered an Ikea Pax wardrobe and now face the challenge of assembling it myself. I want to proceed as efficiently as possible and avoid unnecessary frustration. My question to the community is: What specific tools are actually needed, and in what quality, to make the Ikea Pax assembly as smooth as possible? Is the included tool sufficient, or should I also consider using a cordless drill, specific screwdrivers, or other accessories? I would really appreciate concrete recommendations, especially regarding different wardrobe sizes and possible variations of the Pax system. Thanks in advance!
Repar
12 Oct 2020 18:03
The included Allen wrench set is usually sufficient for assembling the Pax system. If you want to work faster and more comfortably, use a cordless drill with an Allen bit. A Phillips screwdriver is also useful for the back panels. You generally won't need any additional tools.
O
onMarcos
12 Oct 2020 18:27
Hello, to bring a bit more structure here: basically, the Ikea-supplied tool for the Pax is usually sufficient, but it can be quite tiring since it’s mostly a small Allen key. Therefore, I recommend:
- A cordless drill with adjustable torque and the appropriate 4 mm Allen bit for all connections. This saves a lot of time and effort.
- A good Phillips screwdriver (PH2) to easily fasten the back panel and hinge screws.
- Optionally, a spirit level to align the wardrobe precisely.
Common mistakes include overtightening screws, which can cause the wood to split, or inserting screws at an angle. Work slowly and regularly check the alignment. This way, you avoid problems later on.
KESIRI
12 Oct 2020 18:31
Definitely get a cordless drill; the work will go much faster. Allen bits and a screwdriver for the back panel nail are sufficient otherwise. You won’t need anything else.
Giagau
12 Oct 2020 19:02
One point that many overlook is the quality of screwdrivers. I have found that cheap Phillips screwdrivers often damage the screw head, making assembly unnecessarily difficult. Invest in at least one high-quality PH2 screwdriver. For the hex screws, I recommend using the appropriate bits for your cordless drill to ensure a perfect fit and prevent slipping.
Ronki4
12 Oct 2020 19:28
Repar schrieb:
If you want it faster and more convenient, use a cordless screwdriver with a hex bit.
That sounds reasonable. Do you think it’s better to buy an inexpensive cordless drill, or is it worth investing in a more expensive, higher-performance model for this specific assembly? Are there differences in durability or precision that become noticeable?
