ᐅ How can I securely attach Ikea Pax wardrobes to a tiled floor?
Created on: 10 Mar 2020 08:17
Floflo63
Hello everyone, I recently bought an IKEA Pax wardrobe and now want to securely fix it to my tiled floor. Since the floor is very smooth and hard, I’m wondering which mounting techniques or special fasteners you would recommend to anchor the wardrobe firmly and prevent it from tipping over, without damaging the tiles or compromising stability later on. I would appreciate specific advice on suitable fasteners, such as types of anchors, screws, installation methods, or alternatives. Has anyone had experience with special floor anchor systems or adhesive solutions that work well? Thanks in advance!
Glage
10 Mar 2020 12:02
I understand your concerns—tiles can be quite sensitive, especially with expensive designer flooring. I once installed a Pax cabinet on tiles myself and was hesitant about drilling. In the end, I chose to use chemical anchors and carefully protected the drilling area with masking tape.
What also helped me was securing the cabinet with at least two fixing points to prevent any movement. And just in case, I placed a small rubber mat under the bottom of the cabinet to absorb minor unevenness.
This provides some peace of mind in case the floor shifts slightly or scratches occur from sliding. You simply feel more comfortable knowing the whole setup is stable.
raquel52
10 Mar 2020 13:15
Summary of the recommended procedure:
- Drill bit: diamond or carbide drill bit, no hammer function, low speed.
- Mark the drilling spot with tape.
- Pre-drilling with a small diameter is possible.
- Using chemical anchors results in higher load capacity with a lower risk of tile damage.
- Anchoring must be done in the wall (concrete), not on the floor (tiles).
- Use IKEA fixing sets/wall anchors to make the wardrobe tilt-proof.
These steps correspond to the most important safety and quality features when installing a Pax wardrobe on a tiled floor with a concrete structure behind it.
Traman4
10 Mar 2020 14:08
It is important to use the IKEA Pax wall mounting bracket. Fixing the base to the floor is not necessarily required. When drilling, always use a drill without hammer function and chemical anchors for the best hold.
Le_kin
11 Mar 2020 08:55
In addition to the previous tips, I would like to address another important point: load distribution. A large wardrobe often weighs around 100 kilograms (220 pounds), and when you add the frame, clothing, and other items, the total weight can easily exceed 200 kilograms (440 pounds). It is therefore essential that not only individual anchors are loaded, but at least two wall anchors are used to secure the cabinet against tipping.
If you connect multiple cabinets, distribute the attachment points accordingly.
One often underestimated trick is to install small spacers between the back of the cabinet and the wall. These compensate for uneven surfaces and prevent the screws from putting excessive pressure on the tiles when tightened too much.
Please feel free to ask if you need more detailed information on drill diameter, load data, or specific anchor techniques.
Tommy38
11 Mar 2020 09:39
Hello, I’m happy to summarize the key points for you:
- Always use a drill bit appropriate for the type of tile when drilling to avoid cracking the tiles.
- Use chemical anchors designed specifically for solid walls to ensure the best hold.
- Fastening should always be done to the wall, not the floor, to avoid stressing the tiles.
- IKEA provides wall fasteners with the Pax system, which you should definitely install to prevent the wardrobe from tipping over.
If you follow these points, the installation will be safe and stable.
