ᐅ How can a Pax wardrobe be reinforced?
Created on: 5 Nov 2022 19:23
Reoki
Reoki
5 Nov 2022 19:23
Hello everyone, I recently bought a Pax wardrobe from IKEA and have noticed that the structure feels a bit unstable under heavier loads. So, my question to the community is: how can a Pax wardrobe be reinforced, especially when loading it with many heavy clothes and boxes full of household items?
I am interested not only in simple solutions but also in which reinforcements make sense without compromising the design or making assembly more complicated. Which parts of the frame or the back panel are best suited to ensure extra stability? Are there any proven DIY tricks or additional accessories from IKEA or third-party manufacturers that you would recommend?
Looking forward to your experiences and tips!
PAREL
5 Nov 2022 20:12
Hello Reoki, to reinforce your Pax wardrobe, I would recommend the following approach:
- First, check whether the back panel is properly nailed and fully fastened, as the back panel often provides most of the stability in such wardrobes.
- To increase load capacity, metal angle brackets can be installed in the corners. These provide additional support between the side panel and the bottom or top panel.
- Another option is to add center supports or vertical connecting profiles that counteract the span length.
Common mistakes include attaching the back panel loosely or installing the angle brackets incorrectly so that they block the rails or wardrobe doors. Make sure to follow the original assembly instructions carefully and, if necessary, combine them with these reinforcements.
In summary: secure the back panel, strengthen corner joints with metal angles, and add vertical supports if needed. This way, you will have a sturdy base for heavy loads.
PLOMA
5 Nov 2022 21:38
Good evening Reoki, your question about reinforcing the Pax wardrobe is definitely justified when heavy loads are involved. I recommend paying close attention to the construction, as the material is basically good but designed structurally for moderate loads.
First: How is the current back panel attached? In Pax systems, there are thin particle boards used as back panels, which are often fixed only with small nails. These don’t provide much stability, so it’s worth replacing or supplementing them with a thinner plywood board (about 6–8 mm (¼–⅓ inch) wood), which should be additionally fastened with screws and ideally also glue.
Further, I recommend retrofitting metal brackets:
- Choose galvanized brackets and screw them on the inside at all corners between the side panel and the top cabinet panel.
- Use self-tapping wood screws 25–35 mm (1–1¼ inches) long to ensure a secure fix.
Additionally, you can install two cross braces inside, either from wooden battens or steel profiles. These should be firmly screwed in and prevent warping.
A critical question for you: How wide and tall is your Pax wardrobe? The larger the span, the more important middle supports become, which you can achieve, for example, by adding a vertical post.
In summary:
- Reinforce or replace the back panel
- Use metal brackets
- Install cross braces
- Check if middle supports are needed
If you can provide more details, I can offer more specific advice.
neoren
5 Nov 2022 22:07
Secure the back panel properly, screw metal brackets into the corners, and add vertical center supports for large cabinets. This ensures stability.
angelo
6 Nov 2022 07:18
Good morning Reoki, I agree with the suggestions already made, but I would like to add the following:
- Use sturdy solid wood strips as reinforcements on the inside of the side panels. You can attach these with wooden dowels or screws.
- If you place the cabinet in a corner against a wall, an additional screw connection between the back panel/carcass and the wall can provide extra stability.
- Make sure the cabinet feet are properly adjusted (IKEA feet can be rotated). This prevents the cabinet from wobbling and warping under load.
Any measure that firmly connects the side panels, bottom, and top panel will increase stiffness.
faso31
6 Nov 2022 08:54
PLOMA schrieb:
I therefore recommend that you carefully consider the construction, as the material is basically good but designed structurally for moderate loads.
This point is crucial. The Pax wardrobe is not a heavy-duty shelving unit. If you want to store many heavy items continuously, you should not only reinforce it but also reconsider the basic concept.
- What specific loads are you aiming to reinforce? Hanging clothes, boxes, or even heavy equipment?
- Are you loading the shelves to their maximum capacity?
Sometimes it’s not enough to just reinforce with brackets or the back panel; you may need to add modular elements or build a frame structure yourself. For example, in timber construction, cross beams called "joists" are screwed under shelves to prevent sagging.
So my question is: How exactly does Reoki define "reinforcement"? Is it enough to stabilize the cabinet’s structure, or should the shelves also carry heavier loads?
By default, the PAX shelves are rated for a maximum of 10–15 kg (22–33 lb) – beyond that, it becomes critical.
